Home > In Car Electronics (L322) > Satnav disc issues
Page 1 of 3 123>
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Satnav disc issues
Afternoon everyone, i was going to put a new satnav disc in his afternoon but when the old came out the new one won't go back in. It's seeming to get stuck when it's 90% in, not sure why anyone any ideas? Or will it be a case if taking the satnav out?
Cheers
Andy
Post #181710 7th Apr 2013 3:43pm
i can only think that its thicker than the original disc because its a copy? ... - .- -.
Post #181712 7th Apr 2013 3:49pm
andyleeds
Original wont go back in either......
Post #181713 7th Apr 2013 3:58pm
do you mean it wont 'feed/suck' in.. ... - .- -.
Post #181714 7th Apr 2013 4:00pm
andyleeds
It sucks/feeds but stops short before its all in?
Post #181715 7th Apr 2013 4:02pm
try inserting the original disc a few more times ,if this does not work i would try the battery disconnection jobby, failing this its unit out and strip down to see what the obstruction is.. ... - .- -.
Post #181716 7th Apr 2013 4:10pm
andyleeds
Oh dear, have we got stuff on the wiki for this sort of thing?
Post #181717 7th Apr 2013 4:12pm
i dont think so...its strange that it wont go all the way in...a system reboot would be a first step.. ... - .- -.
Post #181719 7th Apr 2013 4:16pm
andyleeds
Disc is jammed now, so will have to take sat nav out.....does the front pop off do u have to take the bolts at the side off....?
Post #181722 7th Apr 2013 4:36pm
i've never done it sorry..i'm sure someone will be on soon that has or knows how.. ... - .- -.
Post #181724 7th Apr 2013 4:41pm
when cd's get stuck in the cd changer ,a tap on the unit with something like a screwdriver will make the cd come out...now i'm not saying that this method will work on the nav unit but its worth a try but be careful .. ... - .- -.
Post #181727 7th Apr 2013 4:49pm
mpirie
Take out the bolts (metric 8mm) two on either side, slide unit out and disconnect the connectors.
Once its out, you might want to take the cover off and see if there is an obstruction.
Another option might be to find the loading motor and see if you can make the carriage go all the way in or out before reassembling it and reconnecting it. Normally its a worm gear driven by the loading motor.
Mike
Post #181728 7th Apr 2013 4:49pm
andyleeds
Cheers guys, will have a crack tomorrow and let you know how I get on.....
Post #181730 7th Apr 2013 5:10pm
andyleeds
ok so changer now out and the disc seems to be stuck on the "roof" of the changer inside any ideas i could get this out short of getting a pair of thin nose pliers in and pulling it out?
Post #181833 8th Apr 2013 2:15pm
if you did get the disc out with pliers with out breaking it ,which is very easily done, you still have to strip the unit down to see why the discs were getting stuck..
i would concentrate on stripping the unit.. ... - .- -.
Post #181837 8th Apr 2013 2:44pm
Page 1 of 3 123>
