Home > Maintenance & Mods (L322) > Water / Condensation in rear lights |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 |
2nd Feb 2013 10:05pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35380 |
how did you get your range into your frontroom then... ... - .- -.
2nd Feb 2013 10:13pm |
Alcohol and eBay is never a good mix
2nd Feb 2013 10:15pm |
good point...i've reversed the car a bit..
2nd Feb 2013 10:28pm |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
The problem is it will come back again My original rear lights on my old 2003 car suffered as did the supercharged ones I replaced them with and now my 2010MY n/s LED does the same Land Rover never did get this right and now they want a puddle before even considering changing them
2nd Feb 2013 10:59pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Happens on my led lights too unfortunately with the leds the light unit does not generate any heat so takes ages to evaporate Present :2008 TDV8 HSE
3rd Feb 2013 12:55am |
Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143 |
Was there ever a recall on the lights because of the water ingress? 2002 Vogue Epsom Green with Ivory Leather.
3rd Feb 2013 9:16am |
Nice way to blister the paintwork |
3rd Feb 2013 9:17am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Have you taken the bulb holders out? The air needs to circulate to get out... Or you will be left with a puddle in the bottom and when it gets cold again the puddle will go all over the inside of your lens again...
3rd Feb 2013 9:26am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
I think the only way to cure the problem is to drill a discrete hole in the bottom of each lens to allow any water that leaks in to drain. |
3rd Feb 2013 9:32am |
So took near side rear light off. Took bulb holder off. Was a fair amount of water in there which surprised me as hadn't seen any when on the car, just fog.
3rd Feb 2013 3:56pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
You should have let it acclimatise before fitting. If it was even at room temperature when you fitted on a cold day, yes, it would probably have condensation. Previously..
3rd Feb 2013 4:02pm |
Fame Member Since: 01 Dec 2012 Location: Oliveira do Hospital Posts: 42 |
nicedayforit's solution works well on my Defender, not one, but two very small holes at base of lenses, allows air in, and fog out. Range Rover Vogue TD6 2002
3rd Feb 2013 5:55pm |
Only works on non led lights though Present :2008 TDV8 HSE
3rd Feb 2013 10:35pm |
