Home > Maintenance & Mods (L322) > Water / Condensation in rear lights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35424 |
that'll work ... ... - .- -.
6th Feb 2013 5:03pm |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 |
Solved the Problem !!!
26th Feb 2013 11:57am |
twhincup Member Since: 22 Feb 2012 Location: byfleet Posts: 109 |
+1, after reading on here, I drilled a couple of discreetish holes, watched niagra falls for five minutes and not had any issues since. Use a small drill bit and you wont even see the hole, although working brilliantly to fix the problem, obviously a 13mm drill bit might not be discreet enough 2007 3.0L Diesel VW Touareg SE 2003 4.4 LPG, Vogue, Silver |
26th Feb 2013 12:40pm |
sorry i didn't get back sooner, I've been at work, but dashed out earlier to get a photo for you:
1st Mar 2013 7:19pm |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 |
thanks for the pics...
2nd Mar 2013 10:27pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
When I did mine I drilled two 3mm dia holes thro the bottom of the units, one in each corner, centred on the joint.
3rd Mar 2013 8:35am |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 |
I also drilled from the underside, in the joint. I used a 0.2 mm (Dremel tool) and drilled three holes. They are totally invisible ----------
3rd Mar 2013 9:12am |
cheers for the help 2011 4.4 TdV8 Nara Bronze |
3rd Mar 2013 12:31pm |
