Home > Maintenance & Mods (L322) > Water / Condensation in rear lights
Page 2 of 3 <123>
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
I did a similar thing but with a slight difference. I drilled a small invisible from the outside hole in mine which worked for a while in standard bulbed lights but not for long.
Then I took out the bulb holders and sat the lamps on the aga overnight suitably insulated from the direct heat. This made them visibly free of condensation. Then I replaced the bulbs and sealed the small holes I had made with superglue. The lights have remained condensation free ever since. At some point the bulb seals will allow some moist air in no doubt but I did this 6 months ago and it has worked til now.
I think if I have to do it again I might try to put some silica gel somewhere in the compartment which could be removed and dried out once a year or something.
T
Post #169848 3rd Feb 2013 10:56pm
googsy2 wrote:
Only works on non led lights though Big Cry
i thought all rear brake lights were led....
i drilled holes as well and it helped muchly but sometimes i still got condensation... ... - .- -.
Post #169869 4th Feb 2013 8:28am
Oh Stan..... Laughing All 09> lights are completely LED i.e. no bulbs = no heat..... Rolling Eyes Laughing Thumbs Up
Post #169873 4th Feb 2013 8:50am
so up till then its brake led and side/fog is a bulb....didnt know that... Thumbs Up ... - .- -.
Post #169874 4th Feb 2013 8:51am
Ahh, then i see the sarcasm was inappropriate sir Bow down Bow down Bow down Laughing
Post #169877 4th Feb 2013 8:55am
didnt take any notice Craig, i'm used to it... Laughing Wink ... - .- -.
Post #169878 4th Feb 2013 8:57am
Laughing Laughing Laughing
Post #169881 4th Feb 2013 8:58am
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
i removed and warmed them in a cooling oven . within a week same issue..
TVRs used to have little garins of silica in the light clusters to prevent condensation ..that didnt work either.. 2011 4.4 TdV8 Nara Bronze
Post #170494 6th Feb 2013 2:51pm
as far as i can see there 3 options to get rid of condensation,
1, buy new units
2, make sure there is an airflow in the unit by drilling small holes in the lens or larger ones in the back of the unit
3, vacuum all the air out of the unit and re-seal it. ... - .- -.
Post #170499 6th Feb 2013 2:57pm
DMRR
Quote:
Oh Stan..... All 09> lights are completely LED i.e. no bulbs = no heat.....
Try touching an LED after it's been on - I think you'll find you'll go OUCH! Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #170504 6th Feb 2013 3:11pm
Googsy
Yes but doesnt radiate the heat enough so that it demists the lens unlike normal non led units were more heat is radiated. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #170512 6th Feb 2013 3:55pm
Pretty much impossible task unless you drill....
Post #170514 6th Feb 2013 3:55pm
Googsy
I have drilled and it doesnt work on the led lights. I have used a vacum cleaner worked for a bit / I have removed and sealed around the gasket with vaseline ( old remedy apparently) and it doesnt work. It clears for a while but when damp it returns. Im sorry I changed mine now to leds . It looks bad on normal lights but on leds it looks nasty. Big Cry Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #170519 6th Feb 2013 4:29pm
drill a larger hole in the back where the hole cant be seen....you need a better air flow... ... - .- -.
Post #170526 6th Feb 2013 4:48pm
Googsy
was thinking i could maybe fit a small solar powered fan in there ! Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #170529 6th Feb 2013 5:00pm
Page 2 of 3 <123>
