Home > Maintenance & Mods (L322) > Water / Condensation in rear lights
Page 1 of 3 123>
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
[/img]
Can anyone guess what Im doing
I figure about an hour in front of the log burner should get the fog out Rolling with laughter Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #169652 2nd Feb 2013 10:05pm
how did you get your range into your frontroom then... Shocked ... - .- -.
Post #169653 2nd Feb 2013 10:13pm
E4 GUY
Rolling with laughter Laughing Alcohol and eBay is never a good mix
Post #169654 2nd Feb 2013 10:15pm
either that or melt the lights......
Not a bad idea though. There is nothing that can't be fixed with a hammer😜😜
Post #169655 2nd Feb 2013 10:15pm
E4 GUY
good point...i've reversed the car a bit.. Arrow
but it is clearing...slowly Alcohol and eBay is never a good mix
Post #169660 2nd Feb 2013 10:28pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
The problem is it will come back again Sad My original rear lights on my old 2003 car suffered as did the supercharged ones I replaced them with and now my 2010MY n/s LED does the same Big Cry Land Rover never did get this right and now they want a puddle before even considering changing them Evil or Very Mad
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #169665 2nd Feb 2013 10:59pm
Googsy
Happens on my led lights too unfortunately with the leds the light unit does not generate any heat so takes ages to evaporate Big Cry Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #169677 3rd Feb 2013 12:55am
Paulhh
Scotland 2002 Range Rover Vogue 4.4 V8 Epsom Green
Was there ever a recall on the lights because of the water ingress? 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #169688 3rd Feb 2013 9:16am
Nice way to blister the paintwork
Post #169690 3rd Feb 2013 9:17am
Have you taken the bulb holders out? The air needs to circulate to get out... Or you will be left with a puddle in the bottom and when it gets cold again the puddle will go all over the inside of your lens again...
Craig Thumbs Up
Post #169693 3rd Feb 2013 9:26am
I think the only way to cure the problem is to drill a discrete hole in the bottom of each lens to allow any water that leaks in to drain.
Post #169699 3rd Feb 2013 9:32am
E4 GUY
So took near side rear light off. Took bulb holder off. Was a fair amount of water in there which surprised me as hadn't seen any when on the car, just fog.
Sat next to the log burner as it was pretty warm.
Fog cleared and thought it was ok.
Tried Mrs' hair dryer to get last bit of mist out , but didn't make much diff.
Refitted light, and maybe because its a little chilly out, fog is back Big Cry Alcohol and eBay is never a good mix
Post #169752 3rd Feb 2013 3:56pm
You should have let it acclimatise before fitting. If it was even at room temperature when you fitted on a cold day, yes, it would probably have condensation. Previously..
Post #169754 3rd Feb 2013 4:02pm
Fame
Portugal 2002 Range Rover Vogue Td6 Java Black
nicedayforit's solution works well on my Defender, not one, but two very small holes at base of lenses, allows air in, and fog out. Range Rover Vogue TD6 2002
Defender TD5 90Hard Top 2001
Range Rover Classic TDi 1994
Mercedes Benz 1959 220S Sedan
Post #169775 3rd Feb 2013 5:55pm
Googsy
Only works on non led lights though Big Cry Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #169846 3rd Feb 2013 10:35pm
Page 1 of 3 123>
