Home > Maintenance & Mods (L322) > Water / Condensation in rear lights
Page 3 of 3 <123
that'll work ... Laughing Thumbs Up ... - .- -.
Post #170530 6th Feb 2013 5:03pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Solved the Problem !!! Razz
Took off for the 3rd Saturday night running. Neutral
Removed bulb holders , dried out overnight
Ran a bead of Araldite epoxy resin along all the edges, regardless of whether seal looked perished.
Not a hint of moisture inside, despite the murky cold weather !
Thumbs Up Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #174634 26th Feb 2013 11:57am
twhincup
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
nicedayforit wrote:
I think the only way to cure the problem is to drill a discrete hole in the bottom of each lens to allow any water that leaks in to drain.
+1, after reading on here, I drilled a couple of discreetish holes, watched niagra falls for five minutes and not had any issues since. Use a small drill bit and you wont even see the hole, although working brilliantly to fix the problem, obviously a 13mm drill bit might not be discreet enough Mr. Green 2007 3.0L Diesel VW Touareg SE
2003 4.4 LPG, Vogue, Silver
Post #174637 26th Feb 2013 12:40pm
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
what diameter were the holes..
were the holes you driller placed in any specific area on bottom of the housing?
cheers 2011 4.4 TdV8 Nara Bronze
Post #174917 27th Feb 2013 10:47pm
twhincup
sorry i didn't get back sooner, I've been at work, but dashed out earlier to get a photo for you:
https://fbcdn-sphotos-e-a.akamaihd.net/hph...9934_n.jpg
https://fbcdn-sphotos-a-a.akamaihd.net/hph...9220_n.jpg 2007 3.0L Diesel VW Touareg SE
Post #175287 1st Mar 2013 7:19pm
goldsax
thanks for the pics...
do yo you think i would get the same effect if i were to drill the hole form the bottom of the units( would need to remove the units, which is a couple of minutes job)?
Post #175484 2nd Mar 2013 10:27pm
When I did mine I drilled two 3mm dia holes thro the bottom of the units, one in each corner, centred on the joint.
If you do it this way use a new drill and be very gentle, minimal pressure on the drill.
If I was doing it again I would put a 2mm drill thro as a pilot.
Works very well, no misting since.
Post #175511 3rd Mar 2013 8:35am
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
I also drilled from the underside, in the joint. I used a 0.2 mm (Dremel tool) and drilled three holes. They are totally invisible ----------
2014 tdv6 (ex. 2004 td6, 1997 2.5 dse)
Post #175515 3rd Mar 2013 9:12am
goldsax
cheers for the help 2011 4.4 TdV8 Nara Bronze
Post #175543 3rd Mar 2013 12:31pm
Page 3 of 3 <123
