Home > Maintenance & Mods (L322) > Water / Condensation in rear lights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35380 |
i thought all rear brake lights were led.... i drilled holes as well and it helped muchly but sometimes i still got condensation... ... - .- -. Y. O. L. O. . |
4th Feb 2013 8:28am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Oh Stan..... All 09> lights are completely LED i.e. no bulbs = no heat..... |
4th Feb 2013 8:50am |
so up till then its brake led and side/fog is a bulb....didnt know that... ... - .- -.
4th Feb 2013 8:51am |
Ahh, then i see the sarcasm was inappropriate sir |
4th Feb 2013 8:55am |
didnt take any notice Craig, i'm used to it... ... - .- -.
4th Feb 2013 8:57am |
4th Feb 2013 8:58am |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 |
i removed and warmed them in a cooling oven . within a week same issue..
6th Feb 2013 2:51pm |
as far as i can see there 3 options to get rid of condensation,
6th Feb 2013 2:57pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Try touching an LED after it's been on - I think you'll find you'll go OUCH! Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
6th Feb 2013 3:11pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Yes but doesnt radiate the heat enough so that it demists the lens unlike normal non led units were more heat is radiated. Present :2008 TDV8 HSE
6th Feb 2013 3:55pm |
Pretty much impossible task unless you drill.... |
I have drilled and it doesnt work on the led lights. I have used a vacum cleaner worked for a bit / I have removed and sealed around the gasket with vaseline ( old remedy apparently) and it doesnt work. It clears for a while but when damp it returns. Im sorry I changed mine now to leds . It looks bad on normal lights but on leds it looks nasty. Present :2008 TDV8 HSE
6th Feb 2013 4:29pm |
drill a larger hole in the back where the hole cant be seen....you need a better air flow... ... - .- -.
6th Feb 2013 4:48pm |
was thinking i could maybe fit a small solar powered fan in there ! Present :2008 TDV8 HSE
6th Feb 2013 5:00pm |
