Home > In Car Electronics (L322) > GPS Antenna removal ?
Johnte
Anyone know how to remove antenna from the roof (do I need to remove headlining) - I want to check connections, as I've lost GPS signal Big Cry
Post #167259 24th Jan 2013 4:42pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Just a thought but you could maybe test the antenna by removing the connection from the GPS unit and plugging it into the aux antenna of an old tomtom or even most mobile phones have an aux antenna port somewhere behind the battery cover.
Post #167266 24th Jan 2013 5:04pm
Stephen.Gazard
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
you can just pull the roof lining away from the tailgate end and reach in you will find a couple of connections attached to the antenna. Stephen Gazard
Range Rover L405 LWB SVA Overfinch / Bespoke
Maserati GT 2017
Maserati Levante Trofeo
Mercedes SL63 AMG
Mercedes S500L
Post #167268 24th Jan 2013 5:08pm
Johnte
Thanks both .. Thumbs Up
Post #167277 24th Jan 2013 6:05pm
daveo
is the antenna not under the rear spoiler Shocked V8 facelift Range Rover Autobiography 22" wheels.
Post #167294 24th Jan 2013 8:23pm
Katash
Think OP is referring to the shark fin antenna - non facelift FF's didn't have those did they?
Post #167296 24th Jan 2013 8:27pm
Johnte
I was thinking the shark fin was the antenna - am I wrong ?
Post #167310 24th Jan 2013 8:55pm
daveo
yep jumped the gun on that one Rolling Eyes V8 facelift Range Rover Autobiography 22" wheels.
Post #167361 24th Jan 2013 10:32pm
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
My 2005 FFRR non facelift has the sharkfin fitted as standard & also the touch screen satnav/tv The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #167363 24th Jan 2013 10:49pm
gabolgi
Spain 2007 Range Rover HSE TDV8 Orkney Grey
Good afternoon
now tell me to the mine happens the same thing, but I don't think is an issue of physical wiring connections
you see the GPS symbol crossed by a line red???
My car is RR de 2006 hse TDV8
Thanks I had a LR3 TDV6, Jaguar XJ 2.7 td, RR Classic 300 Tdi and the winner is RR 3.6 TDV 8
Post #167503 25th Jan 2013 3:35pm
there is no definitive answer re the red line through the gps icon,
you could reset the nav by doing a battery disconnection [info how to in the wiki]
or it could be a bad cable connection
or the nav module is faulty
or you could be in an area where there is no gps signal [snow on the roof of the range?]
or it could sort it self out in time...
just a few things to work through ... ... - .- -.
Post #167508 25th Jan 2013 3:50pm
gabolgi
Thanks Stan, When I buy the car, its battery was empty and to recharge it I had to reinstall everything, and since then appears the lines
Post #167512 25th Jan 2013 4:06pm
a flat battery does cause the red line apparently.. ... - .- -.
Post #167522 25th Jan 2013 5:00pm
gabolgi
Heyyy
Good night
My mechanical say, what the GPS is broke, and the change is 800€
Do You think about this?
THANKSSSSSS I had a LR3 TDV6, Jaguar XJ 2.7 td, RR Classic 300 Tdi and the winner is RR 3.6 TDV 8
Post #169233 31st Jan 2013 9:44pm
get a second opinion from another mechanic... ... - .- -.
Post #169285 1st Feb 2013 9:08am
