![]() | Home > In Car Electronics (L322) > GPS Antenna removal ? |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Just a thought but you could maybe test the antenna by removing the connection from the GPS unit and plugging it into the aux antenna of an old tomtom or even most mobile phones have an aux antenna port somewhere behind the battery cover. |
Stephen.Gazard Member Since: 10 Apr 2012 Location: Bristol Posts: 192 ![]() ![]() ![]() |
you can just pull the roof lining away from the tailgate end and reach in you will find a couple of connections attached to the antenna. Stephen Gazard
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 741 ![]() ![]() |
Thanks both .. |
is the antenna not under the rear spoiler |
Think OP is referring to the shark fin antenna - non facelift FF's didn't have those did they? |
I was thinking the shark fin was the antenna - am I wrong ? |
yep jumped the gun on that one |
ambulancekidd Member Since: 29 Feb 2012 Location: Ayrshire Scotland Posts: 276 ![]() ![]() ![]() |
My 2005 FFRR non facelift has the sharkfin fitted as standard & also the touch screen satnav/tv The reason women's minds are cleaner than a mans mind is that women change their minds more often!
gabolgi Member Since: 25 Jan 2013 Location: Valencia Posts: 8 ![]() ![]() ![]() |
Good afternoon
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
there is no definitive answer re the red line through the gps icon,
Thanks Stan, When I buy the car, its battery was empty and to recharge it I had to reinstall everything, and since then appears the lines
a flat battery does cause the red line apparently.. ... - .- -.
Heyyy
get a second opinion from another mechanic... ... - .- -.
