Home > In Car Electronics (L322) > GPS Antenna removal ? |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Just a thought but you could maybe test the antenna by removing the connection from the GPS unit and plugging it into the aux antenna of an old tomtom or even most mobile phones have an aux antenna port somewhere behind the battery cover. |
24th Jan 2013 5:04pm |
Stephen.Gazard Member Since: 10 Apr 2012 Location: Bristol Posts: 192 |
you can just pull the roof lining away from the tailgate end and reach in you will find a couple of connections attached to the antenna. Stephen Gazard
24th Jan 2013 5:08pm |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 738 |
Thanks both .. |
24th Jan 2013 6:05pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
is the antenna not under the rear spoiler V8 facelift Range Rover Autobiography 22" wheels.
24th Jan 2013 8:23pm |
Think OP is referring to the shark fin antenna - non facelift FF's didn't have those did they? |
24th Jan 2013 8:27pm |
I was thinking the shark fin was the antenna - am I wrong ? |
24th Jan 2013 8:55pm |
yep jumped the gun on that one V8 facelift Range Rover Autobiography 22" wheels.
24th Jan 2013 10:32pm |
ambulancekidd Member Since: 29 Feb 2012 Location: Ayrshire Scotland Posts: 276 |
My 2005 FFRR non facelift has the sharkfin fitted as standard & also the touch screen satnav/tv The reason women's minds are cleaner than a mans mind is that women change their minds more often!
24th Jan 2013 10:49pm |
gabolgi Member Since: 25 Jan 2013 Location: Valencia Posts: 8 |
Good afternoon
25th Jan 2013 3:35pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35248 |
there is no definitive answer re the red line through the gps icon,
25th Jan 2013 3:50pm |
Thanks Stan, When I buy the car, its battery was empty and to recharge it I had to reinstall everything, and since then appears the lines
25th Jan 2013 4:06pm |
a flat battery does cause the red line apparently.. ... - .- -.
25th Jan 2013 5:00pm |
Heyyy
31st Jan 2013 9:44pm |
get a second opinion from another mechanic... ... - .- -.
1st Feb 2013 9:08am |
