Home > In Car Electronics (L322) > GPS Antenna removal ?
gabolgi
Spain 2007 Range Rover HSE TDV8 Orkney Grey
I think so Big Cry Big Cry Big Cry
thakns I had a LR3 TDV6, Jaguar XJ 2.7 td, RR Classic 300 Tdi and the winner is RR 3.6 TDV 8
Post #169307 1st Feb 2013 10:15am
Ipslore
Jersey 2014 Range Rover SVAutobiography 5.0 SC V8 Barolo Black
Just resurrecting this thread as yesterday I lost my navigation, GPS has a red line through it (I was suddenly in the sea as opposed on land!). Running the 753 diagnostics shows the satellites but no signals being received and the self test says all ok so I think my GPS antennae may be goosed. Co-incidentally the hands free phone kit with the phone installed can't find any network either? Any thoughts apart from my own conclusion?
Post #321555 7th Apr 2015 8:51am
the roof mounted pod has both the gps and phone antenna so its faulty cabling or the unit itself..
Post #321576 7th Apr 2015 9:23am
Ipslore
Cheers Stan, I suspected as much - off to Dan then.
Post #321579 7th Apr 2015 9:27am
dan_uk_1984
Did the new antenna resolve your problem?
Do you happen to have the part number and know the cost?
Dan
Post #345981 3rd Sep 2015 9:56pm
Ziggy
Australia
You can take the fin off take it apart 7 or 8 small torx screws remove the PCB for the antenna, buy a generic one off ebay 7 quid remove the PCB from that put it into your fin and away you go very simples quick and cheap fix
my car had not got the phone antenna in so I added that as well, came combined with the GPS from fleabay
Ziggy "Those who cannot remember the past are condemned to repeat it."
George Santayana
Puts away his cloth cap and donkey jacket
Goes and sits in the naughty corner
Post #346017 4th Sep 2015 7:47am
Ipslore
New sharkfin from Ducky Dan was about £60 ex-VAT and yes it solved my problem. Turned out moisture had ingressed between the seal where the antennae meets the roof and over the last few years and I think that goosed the internals or the cables. It's a simple enough job to do but take care with the headlining (I had a mate support it whilst working) as creasing it looked a possibility - not much room to work but if you are half useful with a spanner and take care it is straightforward. Couple of bolts and clips is all.
Post #346924 9th Sep 2015 9:17pm
Same here Sad A paint to remove due to having fat hands but just about doable with the small ratchet and socket on the end Smile the cables were the fiddliest bit as i didnt want to unclip the loom! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #346992 10th Sep 2015 10:54am
