![]() | Home > In Car Electronics (L322) > Wiring route from Engine Bay to Cabin? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Is there a straight forward route to run some wiring from the engine bay into the cabin / accessible behind the dash somewhere? .
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35542 ![]() ![]() |
i remember someone saying that there's a route from behind the battery through into the glove box area and i think the glove box has to be dismantled...... ... - .- -.
Ugh |
is this for your possible fogs-in-grill project, if so you could wire up to the existing fogs with a relay.. ... - .- -.
thanks for that... |
![]() And so shall I ![]() Thanks broncoupe, will investigate. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
@ stan
whats your front fog switch doing at the moment? ... - .- -.
Nada, just on the resistors to prevent dash alert.
you could wire up the main spots to your main headlight switch [with relay] and use the fog switch for the blue leds... ... - .- -.
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
How about using something like this
Thanks Adrian, that's got to have a use in the car somewhere |
SATVC Member Since: 25 Nov 2012 Location: Surrey Posts: 172 ![]() ![]() ![]() |
Did you find a good route to run through???
Not got to this yet SATVC, too cold and too much work on at the moment. Some free time coming up end of March. .
