Home > In Car Electronics (L322) > Wiring route from Engine Bay to Cabin?
Is there a straight forward route to run some wiring from the engine bay into the cabin / accessible behind the dash somewhere? .
Post #163553 10th Jan 2013 10:42pm
i remember someone saying that there's a route from behind the battery through into the glove box area and i think the glove box has to be dismantled...... ... - .- -.
Post #163589 11th Jan 2013 8:21am
Ugh Big Cry .
Post #163626 11th Jan 2013 10:14am
is this for your possible fogs-in-grill project, if so you could wire up to the existing fogs with a relay.. ... - .- -.
Post #163637 11th Jan 2013 10:41am
broncoupe
Drivers side there is a large grommet on the bulk head , carefully piece with something sharp I have a special screwdriver for this possible to use a braddle.
Then pass a thin tube I use plastic beer line this will appear up near wiper mech
Seal the cable with some silicone mastic
Regards
Post #164769 14th Jan 2013 8:27pm
thanks for that... Thumbs Up ... - .- -.
Post #164771 14th Jan 2013 8:30pm
And so shall I Smile
Thanks broncoupe, will investigate. .
Post #164940 15th Jan 2013 3:42pm
@ stan
Yes, but I have funky spotlights with LED rings (on separate circuits). So just weighing up the options of either linking these LED rings up with my DRLs (but that might upset our resident troll Wink) or by having a separate switch for them in the cab.
Got to figure out a good way of securing the spotlights first, without doing too much damage. Not much room in behind the grille for making a secure fixing. So if I strengthen the grille itself this might be an option too.
Nevertheless, useful to find a cable route trhough to the cab, for all sorts of things Wink .
Post #164941 15th Jan 2013 3:46pm
whats your front fog switch doing at the moment? ... - .- -.
Post #164943 15th Jan 2013 3:51pm
Nada, just on the resistors to prevent dash alert.
So main spots (halogens 55w) will go onto that switch, and another switch for the (blue) LED rings. .
Post #164950 15th Jan 2013 4:07pm
you could wire up the main spots to your main headlight switch [with relay] and use the fog switch for the blue leds... ... - .- -.
Post #164953 15th Jan 2013 4:19pm
ahebron
New Zealand
How about using something like this
http://www.ebay.com/itm/UNIVERSAL-12-VOLT-...0077501530
Might make the job a lot simpler as no faffing about behind the dash.
Adrian VW Amarok 2014 Highline auto
Post #165998 20th Jan 2013 9:50am
Thanks Adrian, that's got to have a use in the car somewhere Wink, but perhaps a bit over the top for this particular use. I would probably have used this for the on/off switch for my carpc, but now I have run all the cables and fitted the switch. Anyway, all work on hold as it is too cold and snowy to get out there and do anything Smile .
Post #166020 20th Jan 2013 11:19am
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Did you find a good route to run through???
I'm going to be running 0 gauge amplifier cable but can't see a good route through the bulkhead???
Is there any grommets etc under the battery plate or is there a better way?
Post #174702 26th Feb 2013 7:32pm
Not got to this yet SATVC, too cold and too much work on at the moment. Some free time coming up end of March. .
Post #174715 26th Feb 2013 8:48pm
