Home > In Car Electronics (L322) > Wiring route from Engine Bay to Cabin? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Is there a straight forward route to run some wiring from the engine bay into the cabin / accessible behind the dash somewhere? .
10th Jan 2013 10:42pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
i remember someone saying that there's a route from behind the battery through into the glove box area and i think the glove box has to be dismantled...... ... - .- -.
11th Jan 2013 8:21am |
Ugh .
11th Jan 2013 10:14am |
is this for your possible fogs-in-grill project, if so you could wire up to the existing fogs with a relay.. ... - .- -.
11th Jan 2013 10:41am |
thanks for that... ... - .- -.
14th Jan 2013 8:30pm |
And so shall I Thanks broncoupe, will investigate. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
15th Jan 2013 3:42pm |
@ stan
15th Jan 2013 3:46pm |
whats your front fog switch doing at the moment? ... - .- -.
15th Jan 2013 3:51pm |
Nada, just on the resistors to prevent dash alert.
15th Jan 2013 4:07pm |
you could wire up the main spots to your main headlight switch [with relay] and use the fog switch for the blue leds... ... - .- -.
15th Jan 2013 4:19pm |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
How about using something like this
20th Jan 2013 9:50am |
Thanks Adrian, that's got to have a use in the car somewhere , but perhaps a bit over the top for this particular use. I would probably have used this for the on/off switch for my carpc, but now I have run all the cables and fitted the switch. Anyway, all work on hold as it is too cold and snowy to get out there and do anything .
20th Jan 2013 11:19am |
SATVC Member Since: 25 Nov 2012 Location: Surrey Posts: 172 |
Did you find a good route to run through???
26th Feb 2013 7:32pm |
Not got to this yet SATVC, too cold and too much work on at the moment. Some free time coming up end of March. .
26th Feb 2013 8:48pm |
