Home > Technical (L322) > Damn blumming gearbox |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 956 |
Certainly worth getting the latest software update for the Mechatronic unit. If the problem still persists I would suspect the delay accumulator piston.
1st Dec 2012 10:07pm |
Hi Phil, thanks for the advice. Will first do the software update (Blackbox seems to have the latest update) and see if that resolves the issues.
2nd Dec 2012 8:27am |
To put things in perspective. the tiptronic shifts are silky smooth, it is only the full automatic that struggles with the 3-4 shift. The error code says something along the lines of algorithm based problem. MY 2010 5.0 SC Galway green and sand interior!!
3rd Dec 2012 11:42am |
Decode the synthetic algorithm using Google Maps (Africa) then splice the torsion nipple into the ECU re-set function and then.... change the oil again.
3rd Dec 2012 11:58am |
3rd Dec 2012 12:41pm |
3rd Dec 2012 9:27pm |
There you go just what I said to do.....
3rd Dec 2012 9:28pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Easily explained Gaz! WITCHCRAFT, [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
3rd Dec 2012 10:26pm |
4th Dec 2012 12:23am |
Lots of juju magic around my gearbox I guess
4th Dec 2012 8:27am |
I agree that an ECU software update is definitely the way to go. If components wear, or friction characteristics change, differently to the way ZF expected then they can compensate for this in the updated software.
4th Dec 2012 10:53am |
Well since everyone else agrees so do I |
4th Dec 2012 11:14am |
Hi Phil, BBS actually does have some form of agreement with LR to use their software for ECU updates. That is why I can do a software update to the latest available LR ECU software.
4th Dec 2012 11:38am |
http://www.fullfatrr.com/gallery/displayim...&pos=0
5th Dec 2012 9:19pm |
