Home > Technical (L322) > Driveline Vibration
Philip
Driveline Vibration
I've noticed an unpleasant vibration has appeared on my 2008 TDV8 Vogue.
It's only obvious between around 55 to 85 mph (it isn't noticeable at all at 100+), and is felt most obviously through the seats. You can also see the sunvisors vibrating when they are down. I would say it's coming from somewhere rearwards of the engine, perhaps behind the driver. It's not felt at all via the steering wheel or pedals, there is no accompanying noise and it isn't noticeable under braking.
I've double-checked tyre pressures, tyres and wheel weights and there's no mud, snow or ice accumulated anywhere I can see. Calipers and discs also look fine, and it doesn't appear to be related to engine speed.
Any ideas? Do propshafts or driveshafts go out of balance?
Post #10577 6th Jan 2010 4:10pm
The doc
2008 Range Rover Vogue TDV8 Java Black
I had it yesterday - it was snow making the wheels very out of balance - was fine when defrosted - maybe it could be this?
Call LR assist if your not 100% mate Thumbs Up '09 Freelander 2 TD4 HSE Auto for the Mrs
Using the works Fiesta 1.6 TDCI Sport Van - CHROME FREE THOUGH
Searching for a nice E63 AMG or S8 V10 to replace my "wonky" TDV8
Post #10578 6th Jan 2010 4:35pm
Philip
Thanks. Snow. mud or ice was my first thought - I did very nearly get stuck on New Year's Eve in deep mud hidden under the snow (ploughed some monster furrows getting out) - but I can't see anything untoward anywhere.
I'll give it a good clean underneath once/if everything thaws to eliminate, but I'm 99.9% sure it isn't that..
Post #10582 6th Jan 2010 4:41pm
Vogue
check there is no grass, reeds or other debris wrapped round the prop shaft - after your trip into deep mud - this does cause the symptoms you describe. If it is, the cure is a crawl on your back with a sharp knife...
Post #10587 6th Jan 2010 5:23pm
Philip
Yes, I know the problems grass can cause, I've destroyed the diff seals on a Discovery with it before (I've also spent far too long cutting it out of various PTOs, balers, mowers etc.).
Post #10591 6th Jan 2010 5:54pm
any chance you could have bent the prop when you bottomed it out? Discovery 4 HSE
Post #10592 6th Jan 2010 5:55pm
Philip
It didn't bottom-out as such - I put the nearside onto the snow-covered verge into which it immediately sank, front more so than rear.
Post #10594 6th Jan 2010 6:10pm
case
Did you find the cause of this, I've just started to suffer with the same thing. - or at least the car is....
Post #18703 24th May 2010 5:59pm
Philip
Fixed itself - I think it was frozen mud on the wheels and/or driveshafts.
Now if the battery would stop discharging itself ...
Post #18705 24th May 2010 6:29pm
