![]() | Home > Technical (L322) > Driveline Vibration |
The doc Member Since: 25 Mar 2007 Location: In car hell :-( Posts: 425 ![]() ![]() |
I had it yesterday - it was snow making the wheels very out of balance - was fine when defrosted - maybe it could be this?
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2596 ![]() ![]() |
Thanks. Snow. mud or ice was my first thought - I did very nearly get stuck on New Year's Eve in deep mud hidden under the snow (ploughed some monster furrows getting out) - but I can't see anything untoward anywhere.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3763 ![]() ![]() |
check there is no grass, reeds or other debris wrapped round the prop shaft - after your trip into deep mud - this does cause the symptoms you describe. If it is, the cure is a crawl on your back with a sharp knife... |
Yes, I know the problems grass can cause, I've destroyed the diff seals on a Discovery with it before (I've also spent far too long cutting it out of various PTOs, balers, mowers etc.). |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
any chance you could have bent the prop when you bottomed it out? Discovery 4 HSE
It didn't bottom-out as such - I put the nearside onto the snow-covered verge into which it immediately sank, front more so than rear. |
case Member Since: 05 Aug 2008 Location: Wiltshire Posts: 5 ![]() ![]() ![]() |
Did you find the cause of this, I've just started to suffer with the same thing. - or at least the car is.... |
Fixed itself - I think it was frozen mud on the wheels and/or driveshafts.
