Home > Technical (L322) > 2009 Range Rover TDV8 MY 2010 Bio Diesel Yes or NO?
STMVOGUE2010
Hi All
What do you guys think Bio Diesel for TDV8 yes or no?
If yes where do you get your Bio Diesel?
Very interested in your thought on this one. Thumbs Up Thumbs Up
Post #138315 29th Aug 2012 10:49am
kay323
how much is bio diesel per litre?
Post #138326 29th Aug 2012 11:48am
Depends on your country and where you buy it from. Some places not much less than normal diesel and others much much more Wink
And also where in the country you are Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #138333 29th Aug 2012 12:13pm
Cash2
United Kingdom 2018 Range Rover Autobiography TDV6 Santorini Black
BIO Diesel
Is there anywhere goodin Essex to get Bio Diesel??
Post #138408 29th Aug 2012 8:13pm
Roystonh
Hello - I have found it for £1.25 / litre in New Romney, Kent - would it be safe to use in TDv8 (2011)?
Cheers Roy 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #138411 29th Aug 2012 8:17pm
As above test it and just don't use full tanks for a few. As your in warranty make sure you flush it from the system before taking it in for warranty work or services. Ie run the tank down and only stick £20 in at a time, 3 times should dilute it enough to flush the system out to stop them complaining about it and from smelling it in the workshop Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #138420 29th Aug 2012 8:57pm
haveplan
United Kingdom 2008 Range Rover Vogue SE TDV8 Giverny Green
Was considering doing my own bio (properly mind) but everybody tells me common rail diesels won't last on bio. anyone?
Post #148872 29th Oct 2012 8:55pm
Mix in some 2so to help with keeping things lined, and a little petrol in winter if it gels up. I'd not put more than 1litre of petrol into a full tank of bio though.
To see if it gels just get an old glass jar and half fill it with normal bio, then do the same in another but with the right amount of petrol and 2so and leave them outside somewhere safe and you'll see if it gels up. It will ony affect starting to be honest as the fuel pumps soon heat up the fuel to a good temp just through the power of being heavily compressed Smile
Mine is a td6 though. Don't bother with any of those way exchanger type things. Waste of time. Fbh should be fine on it as well.
I've replaced the secondary pump and in tank pump on mine.
To be honest the secondary is still perfectly fine(I misdiagnosed, the internal tank pump was at fault!)
Another thing some people use is bio winteriser to help keep it liquid in very cold temps Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #148876 29th Oct 2012 9:05pm
marcoos_1
Scotland 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I've got a Landcruiser 4.2TD Amazon that runs on straight vegetable oil. All I do is add maybe £10 of diesel to the veg oil in the winter to stop it geling. I fitted a pre heater kit to the full line so the car starts on diesel from a small secondary tank, then once it's up to temp it switches over automatically to the heated veg oil. I can honestly say it runs much better on the veg oil than diesel. Much smoother, much quieter and no loss of power. I've done about 80,000 miles on it and I tow cars on trailers all the time......not a single issue and I'm getting veg oil free of charge. I've often thought of trying this on my TD6.
I've got a friend making his own biodiesel......haven't been brave enough to try it yet.......I'm a bit worried about quality control!
Post #148889 29th Oct 2012 9:46pm
Won't work on the td6 as its a DI and not IDI setup. Pressures and pump designs and tolerances are miles apart. Te veg even if you could warm it and the lines up enough would still kill the pumps after a short while.
You can buy testing kits for bio and even look on YouTube for simple tests you can do on samples of it Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #148895 29th Oct 2012 10:19pm
haveplan
I've been looking into it for some time now and done lengthy research into the chemical composition (which are very long strings) so I could make bio conforming to legislation. you're allowed to produce 2500 litres for personal consumption before duty becomes applicable but it must not contain more than a tiny percentage of fossil product (1% I believe) and this is very strict indeed.
Post #148928 30th Oct 2012 12:59pm
It's a good allowance Smile allows a td6 to cover 12,600miles at 23mpg which isn't far off most people's average looking at fuelly Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #148929 30th Oct 2012 1:05pm
NO if I am buying it at any stage...... Whistle
Post #148951 30th Oct 2012 5:05pm
Don't fill up at the pumps then as upto 10% of that is BioD... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #148968 30th Oct 2012 7:57pm
Then that's what the car was designed to run on. Anything that would render the factory warranty invalid is a no no in my books. However feel free to run your cars on whatever cheap fuel you can find if it works and your keeping it.
Post #149025 30th Oct 2012 11:40pm
