![]() | Home > Technical (L322) > 2009 Range Rover TDV8 MY 2010 Bio Diesel Yes or NO? |
kay323 Member Since: 08 May 2012 Location: London Posts: 55 ![]() |
how much is bio diesel per litre? |
Depends on your country and where you buy it from. Some places not much less than normal diesel and others much much more |
Cash2 Member Since: 14 Jul 2012 Location: Essex Posts: 75 ![]() ![]() ![]() |
Is there anywhere goodin Essex to get Bio Diesel?? |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 ![]() ![]() |
Hello - I have found it for £1.25 / litre in New Romney, Kent - would it be safe to use in TDv8 (2011)?
As above test it and just don't use full tanks for a few. As your in warranty make sure you flush it from the system before taking it in for warranty work or services. Ie run the tank down and only stick £20 in at a time, 3 times should dilute it enough to flush the system out to stop them complaining about it and from smelling it in the workshop |
haveplan Member Since: 28 Oct 2012 Location: kent Posts: 7 ![]() ![]() ![]() |
Was considering doing my own bio (properly mind) but everybody tells me common rail diesels won't last on bio. anyone? |
Mix in some 2so to help with keeping things lined, and a little petrol in winter if it gels up. I'd not put more than 1litre of petrol into a full tank of bio though.
marcoos_1 Member Since: 25 Oct 2012 Location: Glasgow Posts: 138 ![]() ![]() ![]() |
I've got a Landcruiser 4.2TD Amazon that runs on straight vegetable oil. All I do is add maybe £10 of diesel to the veg oil in the winter to stop it geling. I fitted a pre heater kit to the full line so the car starts on diesel from a small secondary tank, then once it's up to temp it switches over automatically to the heated veg oil. I can honestly say it runs much better on the veg oil than diesel. Much smoother, much quieter and no loss of power. I've done about 80,000 miles on it and I tow cars on trailers all the time......not a single issue and I'm getting veg oil free of charge. I've often thought of trying this on my TD6.
Won't work on the td6 as its a DI and not IDI setup. Pressures and pump designs and tolerances are miles apart. Te veg even if you could warm it and the lines up enough would still kill the pumps after a short while.
I've been looking into it for some time now and done lengthy research into the chemical composition (which are very long strings) so I could make bio conforming to legislation. you're allowed to produce 2500 litres for personal consumption before duty becomes applicable but it must not contain more than a tiny percentage of fossil product (1% I believe) and this is very strict indeed. |
It's a good allowance |
NO if I am buying it at any stage...... |
Don't fill up at the pumps then as upto 10% of that is BioD... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Then that's what the car was designed to run on. Anything that would render the factory warranty invalid is a no no in my books. However feel free to run your cars on whatever cheap fuel you can find if it works and your keeping it. |
