Home > Technical (L322) > 2009 Range Rover TDV8 MY 2010 Bio Diesel Yes or NO?
ebajema
For what it is worth : Based on the limited internet research that I have done sofar, I would run a FFRR diesel (TD6, TDV8, TDV6, SDV8) on 100% bio (I would be looking at keeping the car for a long time anyway). I found very little problems that could actually be linked to the use of bio and the cost and benefit to the environment are substantial. I actually read a few benefits of running bio, such as smoother/better running, cleaning effect on the fuel system (hence less wear and longer life ??)
If I were you, try to find as much "reliable" information on bio the pros and cons related to the engine as you can and then decide. Look specifically for the type of problems you can expect and whether the risk can be perceived as high, medium, low. Look at the estimated cost of repair if any etc. etc. etc.
Being in a high risk / high cost industry has taught me a few things about risk management. The thing is to go for ALARP (As Low As Reasonably Practical) and look at the consequences, not just worst case but also mild case and their cost. As long as it does not jeopardize your or others safety in any way and it is only cost, then it becomes just a simple calculation of cost versus benefits.
By the way if you add 2so, try to use the environmentally friendly stuff used for chainsaws Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #149027 31st Oct 2012 7:40am
Cheers Eb Smile
The Bio does certainly clean and this in itself can cause problems as the amount of gel/gunk that builds up in a tank can be shocking. Marine systems have to use biocides in diesel tanks for this reason! A tiny amount of petrol does the same affect though and is good for cold climes anyway Smile
The lubbing affect can also be good(not too dis-similar from 2so but comes off quicker) so the 2so addition helps longer term Smile
The biggest 2 advantages by far for me are,
1 Engine runs a little quiter than any other TD6 AND smokes little to nothing on full bore. EVER!
2 i dont put any extra CO2 back into the air than the plant had already absorbed in its life Smile
Also being made correctly is the best thing to look for as some makers are very lazy and happy to leave cack in the mix which is never good! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #149047 31st Oct 2012 10:00am
Cash2
United Kingdom 2018 Range Rover Autobiography TDV6 Santorini Black
Hi KingPleb
Where do you buy your Bio from is it in London??
Thanks
Post #149068 31st Oct 2012 12:34pm
Sorry its up in Manchester Sad
Have a bit of a trawl around the net and you will find suppliers local to you. The price varies and dont forget to check the quality and ask other users of it if you can. Vegetableoildiesel forum is good Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #149073 31st Oct 2012 12:47pm
