Home > Maintenance & Mods (L322) > Superchips Bluefin Remap - initial impressions
Page 6 of 6 <123456
My Bluefin arrived this morning, so I thought I'd get it done before I headed for the train to London.
The instruction booklet says there are 2 methods, the first being a dowload straight from the unit itself, and the other which requires an offload of the running map, which is then sent to Superchips to produce a "custom" map. Unfortunately mine was the latter, and by the time I had gotten the mail from them to say it was available for download, I was on my way.
Has anyone else had to do it this was, and is the map really "custom", as it only seemed to take less than an hour for it to be available?
So it'll have to wait until I get home on Sunday to try it out! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #135358 10th Aug 2012 12:50pm
T24RES
Appears to be the 'norm' for the FFRR bluefin Thumbs Up
Post #135361 10th Aug 2012 12:56pm
makes you think how different is your range to anyone else's... ... - .- -.
Post #135362 10th Aug 2012 1:08pm
Time will tell Stan! Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #135365 10th Aug 2012 1:17pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
it doesn't take the tuners long to play with the parameters
Pete Bell emailed mine back within 90 mins.
Post #135391 10th Aug 2012 5:10pm
DMRR
Quote:
JE were publishing figures which showed their tuned 3.6 TDV8 just beating the 4.2 SC to 60.
But we need to see video evidence of this... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #135530 11th Aug 2012 7:33pm
Uploaded the Bluefin map this morning and took the car out for a swift test-drive.
My initial reaction is that the hesitation has definitely gone at pull away and throttle repsonse feels instantaneous.
It certainly feels more powerful, but I will report back after a "spirited" motorway run, but so far, so good! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #135753 13th Aug 2012 5:30pm
Rambles
has anyone tried one of these in the 4.4 ?
http://www.chipexpress.com/products/3033/
Post #135765 13th Aug 2012 7:04pm
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
The reason manufacturers don't make them like is is that it needs to be the right combo of performance, fuel consumption and durability of parts eg brakes, etc. It's always a balance.
I know a specialist tuner who can do a remap for £350 so I'm thinking of avoiding the DIY option if its for the same money and he will know all the pit falls.
As a matter of interest however what exactly is involved? Is a chip physically inserted into the car or is a machine plugged in and the electronics reconfigured? I'm interested to know how they do it. 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #184379 24th Apr 2013 4:12am
It would a good idea to spend a little extra and go to JE Engineering.....
Post #184391 24th Apr 2013 6:59am
They plug a device in.
Read the current software settings.
Save the current software settings to a file.
Then edit a copy of this as they see best to improve the car.
They then save this new file to the car.
They then test it and see if anything is wrong and correct it, ie flat spots, spikes...
Then send you on your way with a lighter wallet Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #184429 24th Apr 2013 10:49am
Rich86
Maybe so but I can get that done by a specialist for the same price. 2009 Vogue TDV8 Nara Bronze
Post #184984 26th Apr 2013 7:18pm
wslr
United Kingdom 2010 Range Rover Vogue SE TDV8 Atacama Sand
Some of the earlier posts about the poor running after mapping could also be due to a modified map having been used with out of date base software. That is why good tuners will take a look at the original software and work out where best to go with the new map. Most tuning equipment will log the software and the hardware coding to help do this.
So it is worth putting the latest software on both the Powertrain and Transmission. Another thing worth doing is to reset the engine adaptions and also the gearbox adaptions just before mapping just so things are neutral when the modified map is used first of all.
Mapping is best done by someone with a very solid background in the subject, not just some bloke with a laptop of generic maps.
Post #185277 28th Apr 2013 1:37pm
Rich86
I agree with that last sentence Wellington.
Post #185289 28th Apr 2013 2:25pm
Page 6 of 6 <123456
