![]() | Home > Maintenance & Mods (L322) > Superchips Bluefin Remap - initial impressions |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
Often dis-cussed is the manufacturers write into the ecu safeguards to protect the engine in the instance servicing routine isn't strictly adhered too. Also they can increase service intervals by not tuning the engine to deliver all it can. I have had my last three cars re-mapped with no issues. I am meticulous with service regime though, I would normally change the oil and filters every 6k miles.
Come in Geoff come in Geoff ! Hope nothing has happened to him with all that extra power! Present :2008 TDV8 HSE
Yousif Member Since: 26 May 2012 Location: Lakes Posts: 37 ![]() ![]() ![]() |
OK I guess that settles it, I'll have to go for it then, the idea of 800Nm of torque is strangely appealing, just hope I don't mess up the planet... |
Had a dispatch notification.
Yousif, offset your fuel use by switching a couple of bulbs to energy saving ones. |
5IMON Member Since: 27 Nov 2011 Location: London Posts: 165 ![]() |
I just ordered one toooo. Solo excited! I wonder if it makes it faster low end than a supercharged |
<chuckle> It's much better than standard that's all I'm going to say |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Uploaded the map, will have to wait for the test drive |
Ignore the knocking and huge cloud on initial startup.....
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
Well so far so good, I usually only drive gently but it is good to know the power is there if/when I need it and it does seem to be there |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
should we start a splinter group ....remapped RR.....RRR |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6770 ![]() ![]() ![]() |
Or we should all have waited and done a group deal with Superchips, but I rather suspect that train has left the station! Got - 2017 SDV8 Autobiography in Loire Blue
Arrived, installed, problem free, very simple process with good clear instructions.
Just to highlight that the standard map as supplied with the Bluefin device for the TDV8 might work better on some cars than on others. I had mine mapped by Evolution chips and the orginal map that was supposed to be suited to most TDV8's made the car run like a dog. Once I contacted them they supplied another map and this time the car was amazing to drive smoother with more power etc. So if some of you are doubtful the map has made a difference this might be the case and I would suggest contacting Superchips as they are likely to have other maps available for the TDV8 which might better suit your car. |
