Home > In Car Electronics (L322) > Sat nav issue
ARH Vehicle Logistics
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Sat nav issue
Sorry if this has been posted before but I think this is a strange one!!!!!!! Been using the nave since I bought the car in jan (2005) vogue. Now when I use the nav it seems to be running slow and becomes very blocky in its movement, seems to run behind where I am on the road and never catches up.
Please help
Russ If i could would you!!!!
Post #130308 10th Jul 2012 6:19pm
You're TD6 is way too fast for the sat-nav to keep up, either lift your foot off the accelerator or stop at the side of the road every few miles to allow it to catch up. Whistle
Post #130309 10th Jul 2012 6:22pm
Whistle Whistle Laughing Done that! Anymore? If i could would you!!!!
Post #130312 10th Jul 2012 6:30pm
JustinP
A dirty or scratched navigation disk may be the cause.
Post #130323 10th Jul 2012 7:12pm
Cleaned and no scratches! Anymore Very Happy If i could would you!!!!
Post #130324 10th Jul 2012 7:29pm
i'd check for water ingress in the rear near side compartment or possibly the laser is faulty and not reading the disc quick enough.. ... - .- -.
Post #130325 10th Jul 2012 7:34pm
Knips
United Kingdom 2017 Range Rover Vogue SE SDV8 Santorini Black
Try another disk (is it a mk3 or mk4?).
Post #130372 10th Jul 2012 10:05pm
SteveMFr
Site Sponsor
2005 - that'll be neither a MKII or IV but a touch screen.
If the disc doesn't fix it check all connectors and the unit itself for humidity (as Stan already posted).
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #130408 11th Jul 2012 7:35am
I had similar with a non land rover sat nav and it turned out to be laser reader in the unit.
Post #130411 11th Jul 2012 7:56am
Thanks for all your tips will try them out when I can ger her arse out of it!!!!!! If i could would you!!!!
Post #130544 11th Jul 2012 4:51pm
Car is now in Bradford having to gearbox looked at again! (another ongoing problem) he called me to say that when he had plugged his reader on the car it was throwing up faults everywhere, trans, susp, stealing, and on and on...... Now I have just remembered that he had had the car the week before I found this issue ( had the battery off) just wondering, he is replacing the battery for me and using the car for a couple of days will the nav needs resetting or anything as to stop this fault happening again.. If i could would you!!!!
Post #137717 25th Aug 2012 7:50am
definitely tell him to reset the steering parameters after fitting the battery....with engine on, turn the steering wheel fully left and then fully right....if you dont do this you will have problems.. ... - .- -.
Post #137736 25th Aug 2012 8:38am
