Home > In Car Electronics (L322) > Sat nav issue |
You're TD6 is way too fast for the sat-nav to keep up, either lift your foot off the accelerator or stop at the side of the road every few miles to allow it to catch up. |
10th Jul 2012 6:22pm |
ARH Vehicle Logistics Member Since: 28 Jan 2012 Location: Shropshire Posts: 61 |
Done that! Anymore? If i could would you!!!! |
10th Jul 2012 6:30pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
A dirty or scratched navigation disk may be the cause.
10th Jul 2012 7:12pm |
Cleaned and no scratches! Anymore If i could would you!!!! |
10th Jul 2012 7:29pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
i'd check for water ingress in the rear near side compartment or possibly the laser is faulty and not reading the disc quick enough.. ... - .- -.
10th Jul 2012 7:34pm |
Knips Member Since: 01 Oct 2011 Location: United Kingdom Posts: 70 |
Try another disk (is it a mk3 or mk4?). |
10th Jul 2012 10:05pm |
2005 - that'll be neither a MKII or IV but a touch screen.
11th Jul 2012 7:35am |
I had similar with a non land rover sat nav and it turned out to be laser reader in the unit. |
11th Jul 2012 7:56am |
Thanks for all your tips will try them out when I can ger her arse out of it!!!!!! If i could would you!!!! |
11th Jul 2012 4:51pm |
Car is now in Bradford having to gearbox looked at again! (another ongoing problem) he called me to say that when he had plugged his reader on the car it was throwing up faults everywhere, trans, susp, stealing, and on and on...... Now I have just remembered that he had had the car the week before I found this issue ( had the battery off) just wondering, he is replacing the battery for me and using the car for a couple of days will the nav needs resetting or anything as to stop this fault happening again.. If i could would you!!!! |
25th Aug 2012 7:50am |
definitely tell him to reset the steering parameters after fitting the battery....with engine on, turn the steering wheel fully left and then fully right....if you dont do this you will have problems.. ... - .- -.
25th Aug 2012 8:38am |
