Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Offroad display ... thing that shows you wheel position etc, also the only way on touch screen to see easily the 'mode' as motorway has no indicator. Check the 'MANUAL' and it will show the mode in their screenshot. It does not occur, EVER. Land Rover Addict
31st Jul 2012 8:10pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
With you now |
31st Jul 2012 8:33pm |
1st Aug 2012 2:22pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
my last FFRR 2005 MY used to display the suspension lowering at motorway speed, i made a point of trying it on a couple of occassions... Current: TDV8 (3.6) RRS HSE
5th Aug 2012 7:29am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
06 onwards FF's dont lower at speed... Simples
5th Aug 2012 8:27am |
where did you get this info from Craig? my face lift 2005 model lowered and my current TDV8 does it as well.
5th Aug 2012 9:12am |
Stu, as far as im aware when the Facelift happened that function was removed hence the light disappearing from the dash... Pre facelift cars lower at 65mph
5th Aug 2012 8:09pm |
Craig..i've never had a light on my dash, was that in the pre facelift models?
5th Aug 2012 8:19pm |
Pre facelift cars have an extra light with a motorway sign. The light that states your car is in "normal height" would go out and the motorway light (your operating light on the left) would come on when the car had lowered itself 25mm... You could also lock it in motorway mode on pre facelift cars...
5th Aug 2012 8:27pm |
ok..well i've learnt two things today then!! the lights on the display and how to adjust my rear wiper.
5th Aug 2012 8:31pm |
Monky Member Since: 23 Jun 2012 Location: London Posts: 7 |
I want!
7th Aug 2012 6:32pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6731 |
The DRL setttings on the IIDTool will bring on the main beam bulbs at varying %age on your original headlights.
7th Aug 2012 6:38pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
Don't see why it would not do it. On my 2005 with IID tool it can be set for main beams (% variable) and also headlights. The wiring to the new lights would just control the same things as the old one, the only difference is the LED sidelights, but they take the control form the sidelights on the older lights so as long as you have resistors it should not make a difference.
7th Aug 2012 7:04pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
Be warned that if you use main beams at 60% in Yorkshire you get a lot of people pulling behind you and flashing their main beams trying to tell you that you're main beams are on. This is obviously solved by letting them overtake and then turning your main beams on properly, optionally (and depending on how agressive they have been) follow them with your main beams on for 20 miles or so
8th Aug 2012 8:31am |
