![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I was recalibrating my ride height following some work on the car, and had the same error as you.
Height calibration doesn’t need tight tolerance mode. 2012 TDV8 Vogue (L322) |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
First clear all faults & then rescan. Wait & see if any come back, if they do, you can then google each code |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 282 ![]() ![]() ![]() |
UPDATE Feedback from GAP says Error code E17 is due to the ECU being requested to exceed its maximum adjustment range of 250. After calibration mine was 254. The root cause is likely to be a mechanical failure of the height sensor mounts or rod.
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I’ve just tried to test and fuel prime my FBH but I’m getting an error message E3. Anyone know what that is?
Grundey2 Member Since: 03 Jan 2023 Location: Lincolnshire Posts: 31 ![]() ![]() ![]() |
Even having an issue for a while, GAP IID tool gives me P0046-77.
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 173 ![]() ![]() ![]() |
anyone with a 07 tdv8 running IIDtool, need help with a default value in CCF.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6744 ![]() ![]() ![]() |
Is it still the case that you can read and clear faults on a car that isn’t registered to the tool?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35499 ![]() ![]() |
i do this on my sons FF so it works for me... ... - .- -.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Yep, it says the vehicle isn't registered but it will read and clear codes if you ask it, it's just the CCF etc that needs payment.... |
Ah ok, maybe I should have persevered with it, I just assumed it wouldn’t read the fault codes. I can’t remember if it gave me the option. Got - 2017 SDV8 Autobiography in Loire Blue
Another quick question. I think I know the answer to this but wanted to be sure, is it only the G3 version that is supported for the MY17> L405? Got - 2017 SDV8 Autobiography in Loire Blue
RiverBlanche Member Since: 20 Apr 2021 Location: Retford'ish Posts: 97 ![]() ![]() |
Hi,
