Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 32 of 49 <123 ... 313233 ... 474849>
gav
United Kingdom 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
Electrical gremlins? long post coming up...
Cant figure out what is going on...
For a few days I've been seeing the air susp inactive message and bong along with the following:
no indicator flash on door locking/unlocking
even sometimes not being able to lock the doors
no steering wheel access movement on turning off the car
erratic mirror dipping/going back to memory position going into reverse
car not recognising the key fob when in proximity and releasing steering lock
I thought it was a flat battery since it is very similar to what happened when I had to change out my battery 8 months ago
Bought a CTEK MXS 5 charger thinking this will solve the issue since we just did a fairly rare 250 mile journey with air con, lights, rear power socket in use and assumed the battery was drained.
According to the CTEK the battery has ok charge - since it got to step 4 after a couple of hours.
Connected the IIDtool today and got:
EAS - 33--k bus fault
Instrument pack - 87--K bus fault
The EAS fault cannot be cleared - update failed
Also some of the ECUs say "no comm with ECU" when I try to read the faults.
Any ideas? Should I start a thread?
Post #277728 27th Aug 2014 4:32pm
i reckon its still the battery.. ... - .- -.
Post #277738 27th Aug 2014 5:32pm
RR2008HSE
^ Ditto. If not, you definitely have enough for a new thread.
Post #277753 27th Aug 2014 6:31pm
gav
Right thanks for the input. battery is charging again. I will let it go through the complete cycle. Might take a while because the car is outside in west wales and I can't leave it overnight.
Air suspension panel lights have gone off now, which is new too.
No clues from the iid fault codes?
Post #277761 27th Aug 2014 7:07pm
gav
Still the same after full cycle of charging
Post #277786 27th Aug 2014 9:03pm
PatGAPInnov wrote:
Hi Guys
The Controller software is installed in conjunction with the updater software (PC only) and will work on V3.0 and up. It can be found here :
Start->All Programs->GAP Diagnostic->IIDContol
Instructions on how to use it are included in the latest version of the user manual, page P10.
Cheers
P.S. SWMBO's : same issue here Whistle
Thanks Patrick, found it, can't wait to try it out Thumbs Up .
Post #277795 27th Aug 2014 9:34pm
Welshdragon
I've not up dated my non BT iid tool but what are the two differences in the versions , 2.17 and 3 ?
will the 2.17 work with the lap top aswell ? If it dont work.......burn it!
Post #277807 27th Aug 2014 10:30pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I have a couple of queries. Sorry if they have been covered before but this is a very long thread.
One of keys no longer works to set/unset the alarm but will work in the ignition. Can I reset the key with my IID tool?
I service my car myself, can I reset the service indicator with the tool?
I have been through the various menus but can't seem to see these two items.
I have a 2003 TD6 if it makes any difference.
Thanks in advance. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #281820 19th Sep 2014 1:29am
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Welshdragon: This thread explains whats in V3.0 http://www.fullfatrr.com/forum/topic22489.html?highlight=iidtool
And yes, V3.0 is required for using the PC controller software. Also, reading the latest user manual is a good place to start.
Mikeyjd:
Key: first, you should verify the condition of the battery or replace it (refer to your owners manual). The immobilizer (anti theft, to start engine) and lock / unlock functions are separated in the remote. The immobilizer does not require any power from the battery while the lock / unlock do. This explains why it can still start the engine.
Service interval reset: this function is not included in the tool for the moment since it can be done without a diagnostic tool. Do a quick search here and you`ll find the procedure. We will eventually add it to the tool also since it speeds things up.
Cheers
Post #281916 19th Sep 2014 3:47pm
Welshdragon
Bow down Thank you sir, I will up date when I can Thumbs Up If it dont work.......burn it!
Post #281933 19th Sep 2014 6:27pm
Ziggy
Australia
I did post this in the "what did you do in your FF today" but thought I'd put another one in here as its a bit more relevant
IID T BT arrived yesterday, thanks Dan Very Happy All sorted this morning updated to latest software Bow down Bow down thanks Pat............
went out and had a play lots and lots of faults Shocked ignore them well cleared them set the chime when locking and unlocking, set global locking on lock Very Happy
this is fun.................
Zigg "Those who cannot remember the past are condemned to repeat it."
George Santayana
Puts away his cloth cap and donkey jacket
Goes and sits in the naughty corner
Post #284042 2nd Oct 2014 3:57am
PatGAPInnov
Site Sponsor
It is fun! Enjoy Thumbs Up
Post #284136 2nd Oct 2014 8:22pm
Just wanted to say how good the IID Tool is. Thumbs Up
However, I've a few questions which I'm sure can be easily resolved:-
1. I've tried activating the auto lock to lock the doors when moving, but it's not doing it. The changes are saved. Is there anything I could be doing wrong?
2. Does a 2007 model need an instrument cluster reset? Would it be of benefit?
3. I can't get my service indicator to show. I can get it via the plugged-in IID Tool but never on the dash display on startup. Is there something I'm not doing correctly?
Si. Si. <This is my name.
Post #284221 3rd Oct 2014 9:33am
pld118
Just plugged my 'new one' in and it says the battery has 12.2 Volts when everything is 'off'. I believe that's a healthy 12.2 Smile
Couldn't get it to tell me anything else due to my ignorance regarding not knowing how to navigate/ what buttons to press so time to read the get started manual methinks Mr. Green
Sent my £25 ownership change/ VIN code fee to GAP today so hopefully not too long now before I can have a play Thumbs Up
Post #284295 3rd Oct 2014 7:43pm
pld118
Can't get IID working
Hi,
With engine running, upon plugging the non BT IID tool in, as pictured, the car shows the 'IID tool Ready' display in accordance with the instructions and then within a second or so, displays 'Voltage: 13.8V'.
However, as per the getting started instructions, I press the Resume/Enter steering wheel switch and yet nothing happens, therefore I can't get the 10 digit code to send to GAP for my VIN unlock procedure. The blue LED light on the IID tool displays a pulsating flash when plugged in.
Basically, I can't get the thing working. Has anyone please got any ideas as to what I'm doing wrong?
Thanks Thumbs Up
Apologies for the upside down pictures... iPad quirk!
Post #284399 4th Oct 2014 5:34pm
