![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
You registered on our site when you activated the IIDTool, so you'll receive mail. We will also post the info, tho. Just in case anyone changes their mail or gave us a fals... mistyped their mail address... ![]() ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
This is very true - but the early (<05) L322 does not have many parameters... This is why we have warnngs all over the user manual. Cliffy, please read before using. And do be aware that going more than 1-2" up or down can potentially leave you in dangerous situations. You could bottom the suspension at speed on a bump and either damage the suspension or - worse - lose control of the RR. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Finally got around to enabling Park Heat today.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
ouch !! ![]() Y. O. L. O. . |
a competitive price of £270 inc delivery found by Graham [A1GSS] here , http://www.island-4x4.co.uk/advanced_searc...=0&y=0 ... - .- -.
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Yes, all good, v quick delivery from Island too.
Stephen.Gazard Member Since: 10 Apr 2012 Location: Bristol Posts: 192 ![]() ![]() ![]() |
I recall that at some point you were looking to add the ability to change the ride height at access level only and leave normal running height untouched on the later models like you could on the earlier model years.
Question:
when you de-pressurize the EAS is disabled.
No worries Steve |
Yes tis. Don't have a 'completely deflate one corner' button. |
Thanks regarding deflating one corner, the bit I missed in the manual was to hold the "-" down.
Actually I did not mention that in reference to the strength - it's the tipsiness. That's why the bfjackstands are good. I've never seen a small one collapse either, but the footprint of the big ones can't be beat. Until I finish my car-barn (floor poured this summer I seriously hope) and install my in-ground lift, I work on a gravel drive too. I know exactly how it is... |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Just swapped out my PDC ECU from an X5 and although working correctly I notice it doesnt 'beep' on activation when reverse is engaged - is it possible to turn this on with IIDTool? |
