Home > Technical (L322) > Blocking protection problem - front wipers
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Suffered same problem last night after wipers had been running non stop for 3 hours. However, back wiper/ wash still worked and that is controlled via same relay ?
Post #299428 17th Dec 2014 9:59am
i doubt it, they have different fuse boxes and different fuses.. ... - .- -.
Post #299429 17th Dec 2014 10:05am
barwik
United Kingdom 2003 Range Rover HSE Td6 Buckingham Blue
Its just happened to mine - exactly the same symptoms - rear wiper is working ok but no fronts in any speed .
Removed the battery , unplugged the relay and sure enough there was a bit of the relay contacts floating in the bottom Smile
I plugged it back in and touched the contacts together with a screwdriver an they started working again - till I break the contacts again -
Brilliant Help - many thanks Very Happy
Post #360399 4th Dec 2015 1:43pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
I can confirm that, on my 2006 TDV6 Range Rover, replacing the relay solved the dead wipers problem. It is in the box behind the battery. I found a BMW relay, code 61.36-8 384 505 (it's the same make and model as the old one) for 15EUR. The old relay seemed to be OK though, no rust or loose parts... Thank you very much RRPhil for your invaluable help!
Post #471122 5th Mar 2018 10:22am
biggie1919
I cant seem to find the relay on my 2011 vogue any pictures to help ? 👍🏽
Post #498191 11th Dec 2018 1:38pm
Mikeinatruck
United Kingdom 2018 Range Rover Autobiography SDV6 Santorini Black
I had this issue today, and my diagnostic would show a missing park signal. Stripped out the motor and checked the switch all good. But after a fair bit of pondering worked out the issue. The signal to the switch is fed via the earth return which is picked up by the tiny lug on the plastic form on the cover, this is connected to the switch, I found that the contact was non existent due to it only being a touch contact, so i put a small blob of solder on the main plate and reassembled and it started working fine. I have circled the two parts in the pictures...
 2018 L405 Autobiograpghy
Post #562827 27th Jul 2020 1:09pm
mjdronfield
I had the issue a couple of years ago, and needed a new wiper motor. Looks like you have got to the bottom of that then.
Bow down 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #562829 27th Jul 2020 1:37pm
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
Just to note, later models don't have this relay behind the battery.
Mine's a September 2011 (2012my) Cam-Tech-Craig just fixed it, had same problems parking half way up screen then cutting out. Needed a new motor in the end and all working fine again.
Thanks to Craig for excellent service Thumbs Up
Post #595558 27th May 2021 7:38pm
Mikeinatruck
You could fix your old one with a switch from RS for £2.60
https://uk.rs-online.com/web/p/microswitch...%3Atrue%7D 2018 L405 Autobiograpghy
Post #595565 27th May 2021 8:29pm
Your welcome Nick and thanks for the business sir Thumbs Up
Post #595580 27th May 2021 10:35pm
