Home > Technical (L322) > Blocking protection problem - front wipers |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35274 |
i doubt it, they have different fuse boxes and different fuses.. ... - .- -.
17th Dec 2014 10:05am |
barwik Member Since: 24 Mar 2015 Location: Lancashire Posts: 9 |
Its just happened to mine - exactly the same symptoms - rear wiper is working ok but no fronts in any speed .
4th Dec 2015 1:43pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 769 |
I can confirm that, on my 2006 TDV6 Range Rover, replacing the relay solved the dead wipers problem. It is in the box behind the battery. I found a BMW relay, code 61.36-8 384 505 (it's the same make and model as the old one) for 15EUR. The old relay seemed to be OK though, no rust or loose parts... Thank you very much RRPhil for your invaluable help! |
5th Mar 2018 10:22am |
biggie1919 Member Since: 11 Dec 2018 Location: Blackburn Posts: 3 |
I cant seem to find the relay on my 2011 vogue any pictures to help ? 👍🏽 |
11th Dec 2018 1:38pm |
Mikeinatruck Member Since: 14 Apr 2016 Location: Dumfries Posts: 50 |
27th Jul 2020 1:09pm |
I had the issue a couple of years ago, and needed a new wiper motor. Looks like you have got to the bottom of that then.
27th Jul 2020 1:37pm |
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 |
Just to note, later models don't have this relay behind the battery.
27th May 2021 7:38pm |
You could fix your old one with a switch from RS for £2.60
27th May 2021 8:29pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Your welcome Nick and thanks for the business sir |
27th May 2021 10:35pm |
