![]() | Home > Technical (L322) > Blocking protection problem - front wipers |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35615 ![]() ![]() |
i doubt it, they have different fuse boxes and different fuses.. ... - .- -.
barwik Member Since: 24 Mar 2015 Location: Lancashire Posts: 9 ![]() ![]() ![]() |
Its just happened to mine - exactly the same symptoms - rear wiper is working ok but no fronts in any speed .
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 800 ![]() ![]() ![]() |
I can confirm that, on my 2006 TDV6 Range Rover, replacing the relay solved the dead wipers problem. It is in the box behind the battery. I found a BMW relay, code 61.36-8 384 505 (it's the same make and model as the old one) for 15EUR. The old relay seemed to be OK though, no rust or loose parts... Thank you very much RRPhil for your invaluable help! |
biggie1919 Member Since: 11 Dec 2018 Location: Blackburn Posts: 3 ![]() ![]() |
I cant seem to find the relay on my 2011 vogue any pictures to help ? 👍🏽 |
Mikeinatruck Member Since: 14 Apr 2016 Location: Dumfries Posts: 50 ![]() ![]() ![]() |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7899 ![]() ![]() ![]() |
I had the issue a couple of years ago, and needed a new wiper motor. Looks like you have got to the bottom of that then.
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 ![]() ![]() ![]() |
Just to note, later models don't have this relay behind the battery.
You could fix your old one with a switch from RS for £2.60
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Your welcome Nick and thanks for the business sir ![]() |
