![]() | Home > Technical (L322) > GM kickdown stutter |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Keep up Martin |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35522 ![]() ![]() |
if there are any more amendments let me know.... |
done |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
Thanks Stan. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
Might be being a bit fussy with the fluid temperature there! Anywhere between 35 & 45 deg. C for the GM transmission (TD6) and between 30 & 40 deg. C for the ZF 5HP24 (V8 petrol) is fine. These are Land Rover’s figures - ZF themselves actually quote 30 to 50 deg. C for their 5HP24. Just a quick reminder on the fluids too : ZF 5HP24 ('02-'05MY V8 ) = Mobil ATF LT71141 GM 5L40-E ('02-'06MY TD6) = Texaco Texamatic 7045E ZF 6HP26 & ZF 6HP28 = Shell ATF M1375.4 ZF 8HP70 (4.4 TDV8) = ZF LifeguardFluid 8 Phil |
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 ![]() ![]() ![]() |
Phil
Sorry Sal, I'm just an amateur working on transmissions that have already been removed from the vehicle, in my garage at home. It's just a hobby. I don't have a vehicle lift or anything like that.
dalziel Member Since: 10 May 2013 Location: Harrogate Posts: 57 ![]() ![]() |
Just about to do this job. How do you check temperature of transmission oil prior to final top up? |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
As above
