Home > Technical (L322) > GM kickdown stutter
Keep up Martin Wink Thumbs Up ( I think Stan has edited the original post ) .
Post #115402 29th Mar 2012 1:17pm
if there are any more amendments let me know.... Thumbs Up ... - .- -.
Post #115418 29th Mar 2012 2:18pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Thanks Stan - I suggest that it would be useful to change the penultimate paragraph of the locked forum thread to say something like this:
Amendments (with thanks to RRPhil):
- If possible, use a genuine Filtran replacement filter
- Replace fluid with fresh fluid until it starts dripping out of the fill hole
Both the ZF & GM transmission fluid levels need to be set with the engine (and therefore the transmission oil pump) running so that the torque converter, oil cooler and its pipes are all full of fluid and not draining back down into the sump.
- Start engine, hold foot brake down and cycle through each gear position holding for 5s (from park to drive & back) to ensure that the valve block galleries are full. Ensure that you finish in Park with the handbrake on.
- WITH THE ENGINE STILL RUNNING wait for the transmission fluid to reach 43C and top up as necessary
- Refit fill plug, tighten and turn ignition off
- Reset the transmission/ gearbox controller (with ignition off, push accelerator pedal to the floor; ignition to position 2; continue holding accelerator pedal to floor for 60s; ignition off; pedal release)
Post #115456 29th Mar 2012 3:43pm
done Thumbs Up ... - .- -.
Post #115468 29th Mar 2012 4:41pm
VaguelyVogue
Thanks Stan. Thumbs Up
Now for the scary bit - after topping up to the correct level, the car drives like a different beast with only a small prod required on the accelerator to generate the required speed...
Post #115486 29th Mar 2012 5:54pm
RRPhil
VaguelyVogue wrote:
...wait for the transmission fluid to reach 43C and top up as necessary
Might be being a bit fussy with the fluid temperature there! Anywhere between 35 & 45 deg. C for the GM transmission (TD6) and between 30 & 40 deg. C for the ZF 5HP24 (V8 petrol) is fine. These are Land Rover�s figures - ZF themselves actually quote 30 to 50 deg. C for their 5HP24.
Just a quick reminder on the fluids too :
ZF 5HP24 ('02-'05MY V8 ) = Mobil ATF LT71141
GM 5L40-E ('02-'06MY TD6) = Texaco Texamatic 7045E
ZF 6HP26 & ZF 6HP28 = Shell ATF M1375.4
ZF 8HP70 (4.4 TDV8) = ZF LifeguardFluid 8
Phil
Post #115664 30th Mar 2012 5:35pm
salb
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
Phil
Do u work on these boxes, as in do u have a garage, need
To flush mine out.
Sal RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
STAINLESS STEEL EXHAUST O/F
CARBON FIBRE WING MIRRORS & A PILLARS & CENTRE CONSOLE
Post #115666 30th Mar 2012 5:40pm
RRPhil
Sorry Sal, I'm just an amateur working on transmissions that have already been removed from the vehicle, in my garage at home. It's just a hobby. I don't have a vehicle lift or anything like that.
Phil
Post #115683 30th Mar 2012 7:06pm
dalziel
2003 Range Rover SE Td6 Epsom Green
Just about to do this job. How do you check temperature of transmission oil prior to final top up?
Post #191936 3rd Jun 2013 10:42pm
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
As above
And what does resetting the gearbox controller do?
Post #192121 5th Jun 2013 8:01am
