![]() | Home > Technical (L322) > Jacking - a simple query |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
@mikey...the wheel needs to get about an inch of the ground really so anything above that is a waste...
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 ![]() ![]() ![]() |
I'm assuming when you say "trolley jack", you're referring to 1 of those hydraulic things? steel wheels & an arm you "pump" to raise the jack, then a screw-type thing to lower it?
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
If that were my husband who spoke to me like that I'd leave him there |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
@Jim:
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
SWMBO asked me what I wanted for Christmas and when I told her she thought I had lost the plot. I already had two small sets of axle stands that are rated at 3 tonnes, but they are only just up to the job and I never felt they were safe enough when working under the FFRR, so here are my FFRR axle stands |
m90got Member Since: 18 Oct 2011 Location: scunthorpe Posts: 120 ![]() ![]() ![]() |
Other than the jacks from Costco what other makes and models are suitable to lift the FFRR up
have a look on machine mart..i brought mine from there , 3 ton with a 520mm lift height..
Thanks Stan will do Current Stable:
My trolley jack is rated 6,000 pounds; 21" lift height.
Only if you lift all 4 wheels off the ground at once. |
