Home > Technical (L322) > Jacking - a simple query
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
I managed to use the scissor jack twice. One on each side of the car to change wheels back and forth.
First one went ok, second one, the jack was already bent so it was pretty scary...
Nevertheless it got the job done with more 10k available for the set of tires.
Now I'm looking into one of those bottle jacks..
What's the lift height you need to have on one of those to use it with a RR?
Post #109270 24th Feb 2012 11:56pm
@mikey...the wheel needs to get about an inch of the ground really so anything above that is a waste...
like i've said before i've jacked with the scissor jack under the bodywork and a trolley jack under the axles and both times i've no problems [except for the flimsy scissor jack]
when releasing the jack ,sometimes the range would go right down to the bump stops ,sometimes it goes to the access height but as soon as you start the engine it all levels out...
Post #109278 25th Feb 2012 9:07am
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
I'm assuming when you say "trolley jack", you're referring to 1 of those hydraulic things? steel wheels & an arm you "pump" to raise the jack, then a screw-type thing to lower it?
That's all I use to lift any of my vehicles.
And if I'm removing a wheel, or have to get under it for any reason, I put it on jack-stands.
Don't EVER trust a scissor jack, bottle jack, or trolley jack to support a vehicle if you're under it.
Scissor jacks, as you've seen, can collapse.
A weak hydraulic seal, and that bottle jack or the trolley jack drops.
It only takes an extra couple minutes to put the jack stands under the vehicle.
Can you even imagine what your wife would have to do, when she hears you screaming in the garage, & comes out to find your arm or leg pinned under that truck?
"OK, honey, no, I'm fine. See that jack over there? No, not the bent one, no, not the one leaking hydraulic fluid out on the floor, the other one. Right. Could you lift that 60 pound jack over here? Good. Now, put that part under the axle. No, the axle is this long thing sitting on my thigh. Pull that handle out, stick it in the end, and pump it.
Yes, dear, I know it's hard to do, that's why I didn't bother. Great. Now, drag me out from under, don't mind the blood. No, it's OK, they can put that bone back in. Can you haul me up into your car & run me over to the emergency room? Thanks, hon. I'm just going to pass out now." Jim
2000 NAS HSE
2005 NAS HSE
Post #109564 26th Feb 2012 11:27pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
If that were my husband who spoke to me like that I'd leave him there Twisted Evil Laughing
Post #109565 26th Feb 2012 11:31pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
@Jim:
Laughing Thumbs Up
Post #109579 27th Feb 2012 9:34am
SWMBO asked me what I wanted for Christmas and when I told her she thought I had lost the plot. I already had two small sets of axle stands that are rated at 3 tonnes, but they are only just up to the job and I never felt they were safe enough when working under the FFRR, so here are my FFRR axle stands Thumbs Up
Post #109586 27th Feb 2012 10:06am
m90got
United Kingdom 2003 Range Rover HSE Td6 Alveston Red
Other than the jacks from Costco what other makes and models are suitable to lift the FFRR up
i ask because i would imagine i will need a good height range and if im spending alot of money on one i want to get it right first time Smile Current Stable:
Range Rover 2003 TD6 HSE Alveston Red, Sand Leather
Ford Focus C-Max silver 2003
V/W transporter Blue 1995
Yamaha XJR1300 Yellow 2002
Kawasaki ZX7R Green 1998
Honda CBR 600 Black 1998
Yamaha RD125LC Mk1 Red 1986
Yamaha RD125LC Mk1 Blue 1986
Post #109653 27th Feb 2012 3:21pm
have a look on machine mart..i brought mine from there , 3 ton with a 520mm lift height..
http://www.machinemart.co.uk/shop/product/...l-garage-j
Post #109655 27th Feb 2012 3:25pm
m90got
Thanks Stan will do Current Stable:
Post #109656 27th Feb 2012 3:27pm
jim2RRs
My trolley jack is rated 6,000 pounds; 21" lift height.
The jack stands are 6,000 lbs EACH.
Manual says petrol FFRR is 5377 - 5644 pounds, unladen weight.
(300 pounds variance for what?)
24 gallons of gas @ about 6 pounds per gallon is another 145 lbs.
oil & various other juices is probably 50 more pounds, easily.
So, 5644 + 200 = 5844 pounds.
Cutting it close to my 6,000 lb. jack. Jim
2000 NAS HSE
2005 NAS HSE
Post #109747 27th Feb 2012 6:48pm
Only if you lift all 4 wheels off the ground at once. Laughing
Post #109756 27th Feb 2012 7:10pm
jim2RRs
duh. good point.
where's the "palm smack" emoticon? Embarassed Jim
2000 NAS HSE
2005 NAS HSE
Post #109831 27th Feb 2012 11:32pm
