Home > Technical (L322) > Jacking - a simple query
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
This may seem like a daft question but what is the best way to jack the car - suspension raised or at access height?
I am going to change my rear pads tomorrow, so don't really need much ground clearance, just getting the wheels off the ground. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #108851 23rd Feb 2012 5:02pm
Googsy
Never jacked up the L322. On my P38 though I left it in access mode with the boot open as this prevents any movement in suspension. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #108854 23rd Feb 2012 5:20pm
For the rears, I put the hydraulic jack under the air spring with the car in standard height and put an axle stand under the side jacking point for safety.
Post #108859 23rd Feb 2012 6:04pm
in any height, if you jack it up it will just use up all the suspension travel. Annoying.
Keep a door or the tailgate open apparently prevents this. Discovery 4 HSE
Post #108863 23rd Feb 2012 6:22pm
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
Nope. Airsprings always push down, cant "suck" up.
Whatever you do, the suspension will droop fully as you jack the wheel up.
If you start at access, you will have to lift past normal, to high, and only then start to lift the wheel.
Start jacking from high, less effort for you.
David
Post #108865 23rd Feb 2012 6:50pm
mzplcg
Decent trolley jack under the lower suspension arm. Never failed me yet. Thumbs Up
Post #108866 23rd Feb 2012 6:59pm
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Can you not lock out the suspension from inside the car (like I have to when going into a multi-storey car park) "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #108942 24th Feb 2012 7:15am
Yes you can but I'm not sure if this works for wheel changing.
The last time I swapped all my wheels over all I know is that it nearly broke me. I tried access height and off road height, the jack broke and bent and when doing the last wheel up it gave way and car dropped down!
Scary Shocked
sometimes its worth getting a greases monkey with better tools to do some things for the sake of a few quid. Discovery 4 HSE
Post #108964 24th Feb 2012 9:22am
MrP
yep - have to agree - I keep an original LR bottle jack in the car (has a welded cup on the top to stop it slipping) that has enough lift to raise the car easily. I definitely don't trust the scissor jack. Must have a look for the 3ton trolley that is often mentioned on here. "On first name terms with my local Dealer......now."
Post #108965 24th Feb 2012 9:27am
JW911
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
A 3 ton trolley is the key. I bought the Costco one not so long ago. It took less than thirty minutes to change all four tyres and I wasn't rushing. What would be helpful is some means of easily lining the wheels up with the hub and I may give Red Bull a run for their money. 2012 4.4 TDV8 Westminster
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #108968 24th Feb 2012 9:35am
T24RES
Use a trolley jack, my scissor collapsed at its first outing dumping the car on its disc Big Cry
Post #109145 24th Feb 2012 4:24pm
as it happens, i had a blowout on the december salisbury plain trip and the scissor jack worked remarkedly well..but i think i was just lucky cos they are Censored really...
Post #109146 24th Feb 2012 4:26pm
Mikeyjd
Well in the end, I put it at max height and used a trolley under the suspension. Interesting to read the different theories on height for jacking though. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #109260 24th Feb 2012 10:49pm
i really dont think it matters what mode the suspension is in ..i've jacked in all 3 and had no problems...it doesnt say in the manual either ....
Post #109261 24th Feb 2012 10:55pm
Mikeyjd
I know, just wondered that it might make a difference to how much you need to jack to lift the wheels off the ground. It isn't really relevant if you use a trolley jack, but using the flimsy scissor jack in an emergency, you wouldn't want to have to lift such a heavy vehicle too high. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #109265 24th Feb 2012 11:07pm
