Home > Technical (L322) > Pressure release valve MAV 500010. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1406 |
Very interesting . I wonder if this is a cause of my pressure static when filling error. V8 or else ... |
24th Feb 2012 8:31pm |
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 |
I have read up on this quite a lot. From my own investigation the pressure release value has no real day to day functions as far as I investigated, apparently information from the head tech overlooking this RR3 design was this was put in place as a fail safe item for when the RR's were being built. I cant remember the exact reason however it was eliminate human error and keep the air pressure correct in the system during its build.
24th Feb 2012 9:01pm |
It really could explain why I get the error in the cold weather.
24th Feb 2012 9:13pm |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 |
Be interested on how you get on, mine does not have the straight connecter as in the picture. I found the picture from another thread, but did find some extra info which makes things even more complicated!!
27th Feb 2012 9:19pm |
Forgot to mention I resolved my air suspension inactive by replacing the pressure sensor last week in the air reservoir under the foot plate, a job RAVE says you can’t do. Found a new genuine part on e-bay for £29 so cheap fix if it holds out.
27th Feb 2012 9:36pm |
Well, I've not had an error since removing the valve ... admittedly, its only been a few days and not particularly cold, but in the past, i would have expected it to come back by now ( yes, it was that regular ). I've not really been driving it much ( the wife has been ) ... I'm not sure, but i'm suspecting i'm hearing the compressor run less.
28th Feb 2012 11:27pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2942 |
I have this error messager
7th Mar 2012 7:22pm |
Even though the fault is a soft fault ( i.e. can reset itself in the EAS ECU next time you start the car ) The fault is likely still in the ECU. If I understand things correctly:
7th Mar 2012 8:04pm |
petewild Member Since: 14 Mar 2013 Location: Croydon, Surrey Posts: 45 |
Hi there,
1st Oct 2013 12:52pm |
Yes. Just remove the air lines and connect them together. I've had no faults since doing mine. |
5th Oct 2013 10:01am |
Well thanks for the info, I must admit I took a look in the wheel well and it looked pretty obvious so I took a chance and did it.
6th Oct 2013 2:10pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 |
I had a go at this today, have had the fault a couple of times whilst just driving along minding my own business. IID tool live values tells me reservoir pressure is holding OK.
29th Jun 2014 4:07pm |
Well that didn't last long. Drive to work (22miles) was fine, but bonged "Air Susp Inactive" within a mile of setting off for home. (Car said 22 C outside temp). I drove it home and plugged in the IIDTool to clear the fault (the same one static pressure in reservoir).
1st Jul 2014 5:04pm |
Having fun with fault code 0x74 ! (Static pressure in reservoir one)
3rd Jul 2014 8:40pm |
