![]() | Home > Technical (L322) > Pressure release valve MAV 500010. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1472 ![]() ![]() |
Very interesting . I wonder if this is a cause of my pressure static when filling error. V8 or else ... |
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
I have read up on this quite a lot. From my own investigation the pressure release value has no real day to day functions as far as I investigated, apparently information from the head tech overlooking this RR3 design was this was put in place as a fail safe item for when the RR's were being built. I cant remember the exact reason however it was eliminate human error and keep the air pressure correct in the system during its build.
It really could explain why I get the error in the cold weather.
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 ![]() ![]() ![]() |
Be interested on how you get on, mine does not have the straight connecter as in the picture. I found the picture from another thread, but did find some extra info which makes things even more complicated!!
Forgot to mention I resolved my air suspension inactive by replacing the pressure sensor last week in the air reservoir under the foot plate, a job RAVE says you can’t do. Found a new genuine part on e-bay for £29 so cheap fix if it holds out.
Well, I've not had an error since removing the valve ... admittedly, its only been a few days and not particularly cold, but in the past, i would have expected it to come back by now ( yes, it was that regular ). I've not really been driving it much ( the wife has been ) ... I'm not sure, but i'm suspecting i'm hearing the compressor run less.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I have this error messager
Even though the fault is a soft fault ( i.e. can reset itself in the EAS ECU next time you start the car ) The fault is likely still in the ECU. If I understand things correctly:
petewild Member Since: 14 Mar 2013 Location: Croydon, Surrey Posts: 45 ![]() ![]() ![]() |
Hi there,
Yes. Just remove the air lines and connect them together. I've had no faults since doing mine. |
Well thanks for the info, I must admit I took a look in the wheel well and it looked pretty obvious so I took a chance and did it.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
I had a go at this today, have had the fault a couple of times whilst just driving along minding my own business. IID tool live values tells me reservoir pressure is holding OK.
Well that didn't last long. Drive to work (22miles) was fine, but bonged "Air Susp Inactive" within a mile of setting off for home. (Car said 22 C outside temp). I drove it home and plugged in the IIDTool to clear the fault (the same one static pressure in reservoir).
Having fun with fault code 0x74 ! (Static pressure in reservoir one)
