Home > Technical (L322) > Temp warning 'bing'
RRPhil
The Faultmate allows you to disable it.
Phil
Post #99224 24th Dec 2011 1:16am
didnt know that phil, thanks for letting us know..
you could remove the temp sensor from behind the grill and route it into the engine compartment to shield it from the cold ,but then you wont get a real time temp reading .. ... - .- -.
Post #99236 24th Dec 2011 10:49am
Phil.
Is Faultmate a specialist bit of kit - complete novice here?
Is it something that a good independent is likely to have access to?
Post #99449 26th Dec 2011 10:55pm
ebajema
Hi Phil, a Faultmate is specialist kit and quite expensive. It should be able to do almost everything the special Landrover dealer computer can do. The outfit selling it is called Black Box Solutions and they are located on Cyprus. I specifically bought mine as I don't want to be dependent on the ridiculously expensive stealers in Nigeria. Also I plan to travel Africa overland in a few years time so it will be handy to have the Faultmate.
Faultmate is speficially designed for Landrover, Jaguar and Rover. MY 2010 5.0 SC Galway green and sand interior!!
Post #99458 27th Dec 2011 8:01am
fisha
Re: Temp warning 'bing'
Phil. wrote:
It ruins the relaxed environment for me. Anyone know how to turn it off? MY07 by the way.
Are you kidding? Its only a bing sound once in a while. Is it really that bad? Do you drive in silence with the radio off ? ( cause there are a lot of songs out at the mo which are faar more annoying ! Laughing ) Plus, I think its a good idea to have it. I've seen the temp drop very quickly when driving along. Setting off at 7deg and quickly dropping to zero or below where I am. I've seen it drop 3 deg in the space of a few hundred yards before
and I'm glad it binged at me for it. V8 or else ...
Post #99559 28th Dec 2011 5:10pm
Phil.
Thanks for your helpful comments. In short, yes I am serious and would remove it if I could hence the question to the experts. My previous FFRR suffered from lots of issues over 18 months and it's the same 'bing' that tells you disaster has arrived yet again. So I'm programmed to expect the worse when the 'bing' comes and the last thing I need the RR to do is it to tell me is when its getting cold (not even freezing) outside. I'm pleased you find it so useful and reassuring though.
Post #99576 28th Dec 2011 5:54pm
Phil.
Cheers for the helpful advice. Enjoy Nigeria, I have visited Lagos many times - an exciting place to be Wink
Post #99577 28th Dec 2011 5:55pm
SteveB
United Kingdom 2006 Range Rover Vogue SE TDV8 Santorini Black
Yes I agree it would be nice to turn it off. I have a reoccurring electrical sensor error that starts with the double bing then lists engine fault, lowered suspension fault, transmission fault - limited gears only, HDC fault system not available and finally parking brake fault. So when I get a single bing because its 5 degrees or less it makes one a little nervous. Steve B
RR TDV8 56 VSE
Post #101277 12th Jan 2012 8:33am
ebajema
@Phil, it is very exiting and very quiet at the moment Smile Ikoyi and VI are virtually deserted although Awolowo road had demonstrations yesterday that got a bit heated apparently. Saw some burned out stuff when I went down the road in the evening. Great driving (have to go to VI in the evening to visit hospital every day) but hard to get stuff (food, petrol etc.). Still nice to live anyway. MY 2010 5.0 SC Galway green and sand interior!!
Post #101282 12th Jan 2012 9:09am
SteveMFr
Site Sponsor
Actually, it must be that bad - at least for some who have gotten burned by Land Rover's modest Rolling Eyes pricing policies. Phil isn't the first person who has brought this up. I have seen at least 2 other threads on the same topic. And in our family it's my wife who goes pale at every bong (She's the controller. I'm just responsible for outgoing cash Whistle ). One guy on RR.net described the feelings the bong summoned as 'my wallet opening and the thousand dollar bills floating out' Laughing .
Phil, as RRPhil said, the Faultmate allows changing this. You can ask around - there are indys who have a Faultmate to service RRs. Or you can wait a bit. We are working on this option for the IIDTool as well.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #101283 12th Jan 2012 9:10am
