![]() | Home > Technical (L322) > Temp warning 'bing' |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
The Faultmate allows you to disable it.
Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
didnt know that phil, thanks for letting us know..
Hi Phil, a Faultmate is specialist kit and quite expensive. It should be able to do almost everything the special Landrover dealer computer can do. The outfit selling it is called Black Box Solutions and they are located on Cyprus. I specifically bought mine as I don't want to be dependent on the ridiculously expensive stealers in Nigeria. Also I plan to travel Africa overland in a few years time so it will be handy to have the Faultmate.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1459 ![]() ![]() |
Are you kidding? Its only a bing sound once in a while. Is it really that bad? Do you drive in silence with the radio off ? ( cause there are a lot of songs out at the mo which are faar more annoying ! ![]() and I'm glad it binged at me for it. V8 or else ... |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 791 ![]() ![]() ![]() |
Cheers for the helpful advice. Enjoy Nigeria, I have visited Lagos many times - an exciting place to be ![]() |
SteveB Member Since: 12 Jan 2012 Location: Kent Posts: 56 ![]() ![]() ![]() |
Yes I agree it would be nice to turn it off. I have a reoccurring electrical sensor error that starts with the double bing then lists engine fault, lowered suspension fault, transmission fault - limited gears only, HDC fault system not available and finally parking brake fault. So when I get a single bing because its 5 degrees or less it makes one a little nervous. Steve B
@Phil, it is very exiting and very quiet at the moment |
Actually, it must be that bad - at least for some who have gotten burned by Land Rover's modest ![]() ![]() ![]() Phil, as RRPhil said, the Faultmate allows changing this. You can ask around - there are indys who have a Faultmate to service RRs. Or you can wait a bit. We are working on this option for the IIDTool as well. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
