Home > Technical (L322) > Airbag warning light
the_engineer
United Kingdom 2004 Range Rover Autobiography Td6 Buckingham Blue
Since having removed the steering wheel (it is now re-fitted) the airbag warning light has come on. Does this need to be reset?
Post #98555 20th Dec 2011 8:37pm
Did you disconnect the battery whilst removing the steering wheel?
Post #98559 20th Dec 2011 8:48pm
the_engineer
as per instruction yes I did disconnect the battery. A wise decision I thought as the airbag and wheel electrics were being disconnected
Post #98567 20th Dec 2011 9:27pm
Could be that the rotary coupler has been damaged when you removed the wheel
Post #98580 20th Dec 2011 10:04pm
the_engineer
don't think I damaged anything. Was pretty careful and all the connections went back together as they should
Post #98587 20th Dec 2011 11:19pm
fisha
I disconnected the battery and removed a door airbag after waiting a long time before touching it ... the light is now on and I cant reset it via my faultmate diagnostic tool. grrr. V8 or else ...
Post #99494 27th Dec 2011 10:28pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
It's a garage job, as it's safety related. Any decent garage will be able to reset, unless of course a problem actually exists.
Mine cleared no problems Smile
Post #99495 27th Dec 2011 10:32pm
Ive taken 100 steering wheels off without the light coming on afterwards, so i would say you definately have a fault now. Maybe not plugged in correctly.
Craig Thumbs Up
Post #99497 27th Dec 2011 10:34pm
