Home > Technical (L322) > Battery jump points |
thats a bit pish as OEM batteries should be upto the job, mines on the original battery and still doing well touch wood
10th Dec 2011 10:24pm |
DBMONKEY Member Since: 02 Nov 2011 Location: Kent Posts: 6 |
It's land rover / varta. 90 ah. And 950 amps |
10th Dec 2011 10:37pm |
it should have a CCA rating of 110 as the diesels need this |
10th Dec 2011 10:41pm |
Thx kingpleb, need to upgrade to the Bosch one at some point soon. However, am still confused about the lack of positive jump point in front of the bulkhead... Any ideas? |
10th Dec 2011 10:48pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
My Varta died today, that was a 95
10th Dec 2011 11:02pm |
It should be just infront of the battery on that scuttle panel and be covered with a flap with a 1" '+' sign on it |
10th Dec 2011 11:03pm |
Defo not there, but there is a large red cable going thru that point that then disappears towards the front of the engine bay. Will take a pic and work out how to post on here in the morning. Cheers guys |
10th Dec 2011 11:08pm |
Jpickie Member Since: 02 Nov 2011 Location: Oxfordshire Posts: 44 |
I also have an 07 with the large positive cable running through the bulkhead and don't have a jump terminal or any pyro device as shown in the handbook, sounds like you are not alone! MY2007 S/C - Stornoway / Jet |
11th Dec 2011 12:03am |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
My 2007 TDV8 does not have the forward 'jump' post nor the pyro device. Looks like they decided to do without for us. I think I'm happier without the pyro device to worry about. 2012 5.0L S/C
11th Dec 2011 8:50am |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 |
My 07 TDV8 does have the forward jump post (I know for sure as I had to use it yesterday gotta love the cold weather), not sure about the pyro and it's too cold for me to go have a look! |
11th Dec 2011 8:56am |
The pyro device was removed with the new ford system as I believe most of the SRS was changed with the new ford electronics - they don't have a pyro battery disconnect system.
11th Dec 2011 11:11am |
awclymm Member Since: 09 Jun 2012 Location: Cheshire, UK Posts: 135 |
I have a 57 plate TDV8 Vogue SE and mine doesn't have the jump point in front of the bulkhead - not sure about the pyro, because I don't know what it looks like....! |
14th Dec 2012 12:02pm |
07 TDV8 with no pyro but do have th jump post
14th Dec 2012 12:31pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
07 TDV8 with no pyro and no jump point!
14th Dec 2012 1:14pm |
