![]() | Home > Technical (L322) > Battery jump points |
thats a bit pish as OEM batteries should be upto the job, mines on the original battery and still doing well touch wood |
DBMONKEY Member Since: 02 Nov 2011 Location: Kent Posts: 6 ![]() ![]() ![]() |
It's land rover / varta. 90 ah. And 950 amps |
it should have a CCA rating of 110 as the diesels need this |
Thx kingpleb, need to upgrade to the Bosch one at some point soon. However, am still confused about the lack of positive jump point in front of the bulkhead... Any ideas? |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
My Varta died today, that was a 95
It should be just infront of the battery on that scuttle panel and be covered with a flap with a 1" '+' sign on it |
Defo not there, but there is a large red cable going thru that point that then disappears towards the front of the engine bay. Will take a pic and work out how to post on here in the morning. Cheers guys |
Jpickie Member Since: 02 Nov 2011 Location: Oxfordshire Posts: 44 ![]() ![]() ![]() |
I also have an 07 with the large positive cable running through the bulkhead and don't have a jump terminal or any pyro device as shown in the handbook, sounds like you are not alone! MY2007 S/C - Stornoway / Jet |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
My 2007 TDV8 does not have the forward 'jump' post nor the pyro device. Looks like they decided to do without for us. I think I'm happier without the pyro device to worry about. 2012 5.0L S/C
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
My 07 TDV8 does have the forward jump post (I know for sure as I had to use it yesterday |
The pyro device was removed with the new ford system as I believe most of the SRS was changed with the new ford electronics - they don't have a pyro battery disconnect system.
awclymm Member Since: 09 Jun 2012 Location: Cheshire, UK Posts: 135 ![]() ![]() ![]() |
I have a 57 plate TDV8 Vogue SE and mine doesn't have the jump point in front of the bulkhead - not sure about the pyro, because I don't know what it looks like....! |
07 TDV8 with no pyro but do have th jump post
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
07 TDV8 with no pyro and no jump point!
