Home > Technical (L322) > Lower Tailgate Electrics
Page 1 of 3 123>
Does anyone know how the electrics for the tailgate 'route' as i've replaced the wiring loom for mine as ssomething has happened to it previously, likely involving some sort of ape Sad but i've got everything bar one latch solenoid connected( i need to get one) and the switch wont fire the solenoid off Sad
I dont wont to connect up a duff solenoid( i have 2) as i reckon the motors are burnt out anyway Sad
Also has anyone tried to source the lower tailgate strut as used on armoured versions to make it easier lowering it??
Thanks,
KP Very Happy
Post #78763 1st Sep 2011 8:05pm
dont know exactly what you mean by 'route' mr pleb, but the wiring comes in through a rubber sheathing and goes both left and right on the tailgate..btw the carpet bit comes off very easily..
Post #78795 2nd Sep 2011 8:00am
Right i've replaced the harness, both solenoids on both sides, a new switch as well and still can't get the solenoids to fire when the button is pushed Sad
Is there a fuse for this circuit at all does anyone know?
Post #95645 1st Dec 2011 8:31pm
The lower tailgate motors are fed thro Fuse 16 and then thro a relay.
Just to clarify, its Fuse 16 on the "rear" fuseboard which is numbered on the car as Fuse 86, 10A. Smile
Post #95654 1st Dec 2011 8:59pm
cheers NDF I'll give it a check over tomorrow. May be the relay is fried as well as the wiring wa a right dogs dinner when i got to it Sad
Post #95678 1st Dec 2011 10:40pm
Well checked fuse 16 in the rear fuse box and its a good un Sad
Which relay is it that it uses and is it swappable with another does anyone know?
im stuck at work today and tomorrow so cant check rave Sad
Post #95885 3rd Dec 2011 2:03pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
Re: Lower Tailgate Electrics
Thanks,
KP Very Happy
Jeez, I thought they were plenty light enough already - I think it would only be half the weight of my old Classic's tailgate. Maybe save your pennies and buy a gym membership? Laughing
Post #96009 3rd Dec 2011 11:41pm
2011 models have a strut on the right hand side of the lower bootlid to stop the boot crashing down when you open it... Is that what you mean?
Craig Thumbs Up
Post #96016 4th Dec 2011 3:02am
Might have a nosey at the dealership if im passing sometime craig and see if its what im after as its likely going to be the cheaper option Smile
Don't need a gym membership just want to get the lids opening nice and smooth and not clunking out like some old banger Sad
Post #96018 4th Dec 2011 7:05am
Ok as an update i've ploughed into raves electrical document and found pages 24 + 43 seem to show that the following happens;
Boot switch triggers a signal to the BCU
BCU then sends a trigger signal to the Relay
Relay then sends a 0.7 second burst to the lower tailgate solenoids
This is a right faf compared to the simple nature of just triggering the relay directly and cuts out work for the BCU as well. god knows what else is being pumped into the BCU that should be logically thought out.
Tomorrow will be spent looking at this a little and the upper tailgate issue i now face Sad
Post #96365 5th Dec 2011 7:43pm
Well i've looked at my fusebox doesn't match the one from RAVE Sad
If it did i would have a relay missing Sad
Can anyone with a Vogue, TD6, Pre-facelift (IE 2005>) take a picture of their rear fusebox so i can compare please as it may be that the fuse was popped as well and not replaced by the previous owner Sad
Post #96471 6th Dec 2011 12:58pm
http://www.rangerovers.net/outfitting/towi...onnections
just over half way down is a pic of the fusebox..
Post #96472 6th Dec 2011 1:02pm
Cheers scarey I guess the 5 pin relay is missing then Sad another thing to add to my list Evil or Very Mad
Post #96496 6th Dec 2011 4:27pm
can you not take one out from somewhere else and try to make it works ok.
Post #96497 6th Dec 2011 4:34pm
Fraid not as it's one of the oblong not squares and only other one in there is a 4pin unit Sad will need to pm fan to get a price for it and my wiper motor Sad
Post #96498 6th Dec 2011 4:36pm
Page 1 of 3 123>
