Home > Technical (L322) > Lower Tailgate Electrics |
Does anyone know how the electrics for the tailgate 'route' as i've replaced the wiring loom for mine as ssomething has happened to it previously, likely involving some sort of ape but i've got everything bar one latch solenoid connected( i need to get one) and the switch wont fire the solenoid off
1st Sep 2011 8:05pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
dont know exactly what you mean by 'route' mr pleb, but the wiring comes in through a rubber sheathing and goes both left and right on the tailgate..btw the carpet bit comes off very easily.. |
2nd Sep 2011 8:00am |
Right i've replaced the harness, both solenoids on both sides, a new switch as well and still can't get the solenoids to fire when the button is pushed
1st Dec 2011 8:31pm |
cheers NDF I'll give it a check over tomorrow. May be the relay is fried as well as the wiring wa a right dogs dinner when i got to it |
1st Dec 2011 10:40pm |
Well checked fuse 16 in the rear fuse box and its a good un
3rd Dec 2011 2:03pm |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 |
Jeez, I thought they were plenty light enough already - I think it would only be half the weight of my old Classic's tailgate. Maybe save your pennies and buy a gym membership? |
3rd Dec 2011 11:41pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
2011 models have a strut on the right hand side of the lower bootlid to stop the boot crashing down when you open it... Is that what you mean?
4th Dec 2011 3:02am |
Might have a nosey at the dealership if im passing sometime craig and see if its what im after as its likely going to be the cheaper option
4th Dec 2011 7:05am |
Ok as an update i've ploughed into raves electrical document and found pages 24 + 43 seem to show that the following happens;
5th Dec 2011 7:43pm |
Well i've looked at my fusebox doesn't match the one from RAVE
6th Dec 2011 12:58pm |
http://www.rangerovers.net/outfitting/towi...onnections
6th Dec 2011 1:02pm |
Cheers scarey I guess the 5 pin relay is missing then another thing to add to my list |
6th Dec 2011 4:27pm |
can you not take one out from somewhere else and try to make it works ok. |
6th Dec 2011 4:34pm |
Fraid not as it's one of the oblong not squares and only other one in there is a 4pin unit will need to pm fan to get a price for it and my wiper motor |
6th Dec 2011 4:36pm |
