Home > Maintenance & Mods (L322) > Average life of HIDs ? |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
I was told once by local LR Service Dept they are supposed to have an expected life span of 15000hrs??? - im not sure how correct this information might be
25th Nov 2011 3:12pm |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 |
mine keep flickering too |
26th Nov 2011 1:30am |
^^^ Sorry to hear that Simon. As I mentioned above - its most likely the flickering lights will be caused by your headlamp ballast resistor packs failing and not the actual bulbs themselves.
26th Nov 2011 5:51am |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
No flickering (touch wood) and I'm going to hold off replacing the bulbs for the moment - but thanks for the offer. |
28th Nov 2011 10:25am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35284 |
VV ,they do seem to do that, i replaced mine with cheapo 6000k bulbs of ebay and the difference was dramatic...much brighter and whiter.. |
28th Nov 2011 3:06pm |
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 |
The bulbs drop in output and go pink when they fail - the ballast apparently affects the shutter that sits over the bulb and drops when you select high beam.
29th Nov 2011 9:11pm |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
You can get both the ballast and the ignitors seprately.
29th Nov 2011 9:18pm |
