Home > General > Hankook Ventus ST or General Grabber UHP ? |
Tyre will be only very slightly taller (5mm increase in rolling radius) so may cause minor speedo error. However thewy will fill the arches a little better and should look
25th Nov 2011 11:47am |
If they are the grey ones with thick round spokes I love them |
25th Nov 2011 4:23pm |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
Not sure which they are and cant figure out how to post a picture, they are 10 spoke machine finished with a grey inside. |
25th Nov 2011 4:36pm |
Understand your choice of 275/45 over the 265/50 however: 255/50 = 2327 circumference 8.8 ride quality 265/50 = 2358 circumference 9.6 ride quality (31mm off standard - bigger) 275/45 = 2304 circumference 8.2 ride quality (23mm off standard - smaller) Therefore by choosing 265/45 over 265/50 you have smaller than Standard Wheels and worse ride quality. Persobally I would have gone with the oversize tyre to get the bigger sidewall and comfort factor plus a better fill of arches but there is not much in it |
25th Nov 2011 4:42pm |
I wanted a bit of extra road feel (not as much as the 285/35/22 i just took off) hence the smaller sidewall and wider footprint.
25th Nov 2011 4:49pm |
Is the 275/45/20 the wrong size, i can call the tyre shop and change the order before its too late?. |
25th Nov 2011 4:50pm |
I think they will work very well may just look slightly too small as do all RRS wheel/tyre combos.... |
25th Nov 2011 4:52pm |
Im concerned now |
25th Nov 2011 4:53pm |
Wont the 265 wide tyre be slightly narrow for the 9.5 J wide rims?. Tyre calculators suggest so.
25th Nov 2011 5:00pm |
OK so you have a choice:
25th Nov 2011 5:01pm |
What is the factory standard tyre size for the RRS rims you have? |
25th Nov 2011 5:08pm |
275/40/20 I believe.
25th Nov 2011 5:10pm |
From Standard 275/40 R20:
25th Nov 2011 5:13pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Good work Carlos have you tried AJS 4x4 site sponsor? Reading Gaz's post I would defo go with the 265 option. Present :2008 TDV8 HSE
25th Nov 2011 5:14pm |
