Home > Technical (L322) > Whats the easiest way to get a secondary key for my pre-05
@ daveo re your last two posts - this is exactly what I understood to be the case, that you needed a key to come from LR if you needed another key. There seems to be a lot of mis-information here (not yours daveo Wink)
This must be very confusing for the OP Question .
Post #93633 21st Nov 2011 8:56pm
CUE99T
Do I need to ask this question again...........???
1. I have only ONE key......
2. I have no spare blade or fob
3. I'd like a clear answer cos I'm still confused!!!
Daveo's posts so far as it's making me think it's got to be a dealer order but I can "sync" to car myself, but I takes a chance that it's original locks etc. Did I get that right?
Is it basically a complete dealer order here, but do the manual labour myself? all smug in my new plug!
2021 Westminster Black D300
2013 Vogue SE - gone
Some Porsche Cayenne guff pretending to be a 4x4!!
2006 Vogue
2004 Vogue
2001 Vogue
Post #93650 21st Nov 2011 10:12pm
daveo
its one of those things, like mapping,if you have the equipment to do then your laughing..when i use to chip playstations it was money for old road, a £1.25 chip and 4 wires to solder and there you go £40. until every one started doing it and it came down to £10. the same in the key programming, you can buy the key cases now for £8 and the transponder chip are about a £5 so thats around £13 then just needs programming and as you need a bit of kit thats were the money is..so if there is any one on this forum how knows someone that can do this programming 100%, ask them if they are interested on doing a good price for forum members.
just one thing with reference to mapping i have found someone who does the 4.4 for £175 inc postage.. V8 facelift Range Rover Autobiography 22" wheels.
Post #93659 21st Nov 2011 10:26pm
CUE99T
mapping of what mate? all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #93662 21st Nov 2011 11:17pm
daveo
sorry got carried away with my self, the mapping is for the engine ecu and gives you around 20bhp but better torque and sorts out those flat spots.
ok ..if you have one key only and need an other, its the transponder chip or rather the programming of it in the key you cant get done,the key case, pcb can and can be programmed by your self but with out that chip is no good at all. it seems it's only the dealer that has the equipment to do it and they wont just sell you chip,they will sting you for the whole key... V8 facelift Range Rover Autobiography 22" wheels.
Post #93664 21st Nov 2011 11:35pm
bozmandb9
That wasn't the case when I coded a key from another car to work on mine, using the technique posted on this post. OK it was a BMW E38, but same key, same transponder same technique!
There is no special equipment, no magic, this is what the stealer will charge you loads of money for, and you can do it yourself in a couple of minutes. Thumbs Up Range Rover-less at the moment - Pining!
Post #93666 21st Nov 2011 11:39pm
CUE99T
ah cool......could you pm me the details mate, thanks for your help so far.
think I'll order up a key from stealer as I get a little discount for the moment as my flatmate is trade. all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #93671 22nd Nov 2011 1:43am
duckworthparts
Site Sponsor
pre 05 FFRR key would be £175inc vat, will come programmed and cut to your car.
It will start your RR, but buttons won't work until its programmed in, this can be done by a number of sequences as already previously said. You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #93686 22nd Nov 2011 8:46am
Thanks Dan, that helps to clear all that up Smile .
Post #93742 22nd Nov 2011 1:37pm
duckworthparts
Site Sponsor
Thumbs Up You can paypal direct using - www.paypal.me/duckworthparts
Post #93743 22nd Nov 2011 1:42pm
CUE99T
Will drop you a line in the next week or so to get that ordered. Very Happy all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #93744 22nd Nov 2011 1:57pm
sidmini
United Kingdom 2002 Range Rover Vogue 4.4 V8 Atacama Sand
Daveo could you kindly give me some more info on the remapping of the 4.4, where do you get it done and what do they send you? thanks
Post #93801 22nd Nov 2011 6:56pm
