Home > Technical (L322) > Whats the easiest way to get a secondary key for my pre-05 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
@ daveo re your last two posts - this is exactly what I understood to be the case, that you needed a key to come from LR if you needed another key. There seems to be a lot of mis-information here (not yours daveo )
21st Nov 2011 8:56pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
its one of those things, like mapping,if you have the equipment to do then your laughing..when i use to chip playstations it was money for old road, a £1.25 chip and 4 wires to solder and there you go £40. until every one started doing it and it came down to £10. the same in the key programming, you can buy the key cases now for £8 and the transponder chip are about a £5 so thats around £13 then just needs programming and as you need a bit of kit thats were the money is..so if there is any one on this forum how knows someone that can do this programming 100%, ask them if they are interested on doing a good price for forum members.
21st Nov 2011 10:26pm |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 |
mapping of what mate? all smug in my new plug! 2021 Westminster Black D300 2013 Vogue SE - gone Some Porsche Cayenne guff pretending to be a 4x4!! 2006 Vogue 2004 Vogue 2001 Vogue |
21st Nov 2011 11:17pm |
sorry got carried away with my self, the mapping is for the engine ecu and gives you around 20bhp but better torque and sorts out those flat spots.
21st Nov 2011 11:35pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
That wasn't the case when I coded a key from another car to work on mine, using the technique posted on this post. OK it was a BMW E38, but same key, same transponder same technique!
21st Nov 2011 11:39pm |
ah cool......could you pm me the details mate, thanks for your help so far. think I'll order up a key from stealer as I get a little discount for the moment as my flatmate is trade. all smug in my new plug! 2021 Westminster Black D300 2013 Vogue SE - gone Some Porsche Cayenne guff pretending to be a 4x4!! 2006 Vogue 2004 Vogue 2001 Vogue |
22nd Nov 2011 1:43am |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 |
pre 05 FFRR key would be £175inc vat, will come programmed and cut to your car.
22nd Nov 2011 8:46am |
Thanks Dan, that helps to clear all that up .
22nd Nov 2011 1:37pm |
You can paypal direct using - www.paypal.me/duckworthparts
22nd Nov 2011 1:42pm |
Will drop you a line in the next week or so to get that ordered. all smug in my new plug! 2021 Westminster Black D300 2013 Vogue SE - gone Some Porsche Cayenne guff pretending to be a 4x4!! 2006 Vogue 2004 Vogue 2001 Vogue |
22nd Nov 2011 1:57pm |
sidmini Member Since: 20 Sep 2010 Location: kent Posts: 45 |
Daveo could you kindly give me some more info on the remapping of the 4.4, where do you get it done and what do they send you? thanks |
22nd Nov 2011 6:56pm |
