![]() | Home > Technical (L322) > Interior lighting issue |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
dear mr lazy.. |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
OK Boss, Sir, Dad.... |
cappo , is that the owners manual you looked at cos there's a workshop manual on the wiki to download.. ... - .- -.
Stan, yes, was owners manual, just for fuse numbers - do you think there will be more in the workshop manual? |
probably ...worth a look.. ... - .- -.
Hmm - getting scarey (!) now. Most of the interior lights are controlled by one or other control modules.....I can't see any straightforward reason why they wouldn't be working.
Can I open this one up again?
I presume you have tested each bulb holder thats out for voltage with a multimeter? |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Someone had a similar issue a few months back. Does you light dimmer work? Think their LCM was |
I haven't done yet, no - partly because I'm making the assumption that if the bulbs are OK (tested off the car with 12v) then there won't be any voltage - and partly because I feel that there must be a common fault causing this?
i would go with the common fault idea... ... - .- -.
That's what I fear. Rob - altho I'm fairly sure my dimmer works (will have to go and double-check). Any idea how any mortgages I need for an LCM? (That's located at the bottom of the A pillar somewhere IIRC?) |
"Or is that not a valid assumption?"
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Basics would be check for a voltage at the holder... And also check the neg.earth on the holder, that could be the common link. Previously..
